November 11Nov 11 NCSTATE1978 on page 4 of this disccussion gives an image of the Enphase filter that solved his issues, which were the same as ours (blinking and communication lag)..
November 20Nov 20 @NCSTATE78 I know it sounds like I am stalking you, but you appear to have solved the problems that I am also experiencing. Currently, my installer is recommedning a Gapped Ferrite (65 A) filter on 4 lines. If I recall correctly, this was a "solution" that sort of worked, but not completely. Is there an way for my installer to contact your installer to discus your specific installation to see if we are similar. I wish I knew of a way to Private Mesaage you so I could give you my email address so we could exchange the information that would better ID us for the installer communicaiton. Thanks
November 21Nov 21 23 hours ago, j.rieff said:@NCSTATE78 I know it sounds like I am stalking you, but you appear to have solved the problems that I am also experiencing.Currently, my installer is recommedning a Gapped Ferrite (65 A) filter on 4 lines. If I recall correctly, this was a "solution" that sort of worked, but not completely.Is there an way for my installer to contact your installer to discus your specific installation to see if we are similar. I wish I knew of a way to Private Mesaage you so I could give you my email address so we could exchange the information that would better ID us for the installer communicaiton.ThanksYou can give it a try. My installer missed installing the ferrite cores that come with (and are placed inside) the powerwall3. They installed those and that did not help with insteon. The filters you referenced aren't the same, but are similar to those that tesla provides, so while I don't have experience with those specifically, Ferrite cores in general didn't make a difference for me. The service manager that helped me with this issue no longer works for my installer and without a direct contact, it's not likely you'll get very far without hiring them to service your system. You can try the ferrite cores, but if those don't work, as I mentioned before, I can tell you that the filter I posted above worked for me.
November 21Nov 21 @jkraus I did a little Google search using RPC1508-64. Several good hits. The Enphase page gave me a price around $420. There were some imdependent sources that were around $350 and EBay source in the $230 range. Obviously, there were would be an installation charge and electricians are not cheap.@NCSTATE78 Thanks. Strange that my installer (who does not have a forum id/pw) can no longer see this thread.
