EWhite Posted November 16 Posted November 16 tried several times to update, still shows i need to update. did an incremental get missed again? or is it actually not updating? Thanks! Quote
Panda88 Posted November 16 Posted November 16 I have had some issues with the release system - trying to get the bottom of this Quote
EWhite Posted November 16 Author Posted November 16 1 hour ago, Guy Lavoie said: Update what? IoX? Current version is 5.8.4 the yolink nodeserver, which is the forum i posted this in. Quote
EWhite Posted November 16 Author Posted November 16 1 hour ago, Panda88 said: I have had some issues with the release system - trying to get the bottom of this no biggie...i assume i am updated to latest even tho version shows different. Quote
Panda88 Posted November 16 Posted November 16 To be honest it may not be the case. Can you send me a log file and i can check Quote
EWhite Posted November 16 Author Posted November 16 here it is..hope this is what you need YoLink_11-16-2024_23756_PM.zip Quote
Panda88 Posted November 16 Posted November 16 Did you restart the node and enable debug. If so then I believe I have what I need. I'll check later Quote
EWhite Posted November 16 Author Posted November 16 yes.. i think thats what i did... i actually set log to debug, then tried to upgrade, so it restarted on its own. Quote
Panda88 Posted November 16 Posted November 16 Ok I'll look at the log over the weekend or early next week busy today and tomorrow Quote
dbwarner5 Posted November 18 Posted November 18 Having hte same issue.. Everything appears to go thru the update process: asks for slot, asks to update. Plugin restarts, etc, but version stays on 1.2.5. thanks. attached is log set to info YoLink_11-18-2024_111432_AM.zip Quote
dbwarner5 Posted November 18 Posted November 18 UPDATE: @Panda88 So this time, I Stopped the PI... did the update and got this: But then when I hit START... it reverted back to 1.2.5: Quote
Panda88 Posted November 18 Posted November 18 I am aware of the issue - trying to understand what is happening in the node store 1 Quote
Panda88 Posted Tuesday at 05:30 PM Posted Tuesday at 05:30 PM Universal devices found a bug preventing updates It will get fixed in next release of the PG3x (coming soon) 3.3.14 3 Quote
