Blackbird Posted December 12 Posted December 12 Is there a way to use Insteon dimmer's Fast on/off for an automation in HA? I want to double tap my dining room light on to temporarily disable my Aqara presence sensor. Thanks Quote
larryllix Posted December 12 Posted December 12 If ..... XXX is switched Fast On Then .... do the deed Else -- This is also sent by the non-Dimmer Insteon Wall switches Quote
Blackbird Posted December 12 Author Posted December 12 3 hours ago, larryllix said: If ..... XXX is switched Fast On Then .... do the deed Else -- This is also sent by the non-Dimmer Insteon Wall switches I know how to use fast on/off on the isy. I'm asking how to use it in Home Assistant. In HA there is no option that I can see that detects when an Insteon dimmer is switched fast on/off. Quote
Guy Lavoie Posted December 12 Posted December 12 I know nothing about Home Assistant, but if there is no built-in way to detect that command, could you do through an alternate way, using a ISY program that detects it, changes a variable or something, and then Home Assistant detects that? Quote
Blackbird Posted December 12 Author Posted December 12 1 hour ago, Guy Lavoie said: I know nothing about Home Assistant, but if there is no built-in way to detect that command, could you do through an alternate way, using a ISY program that detects it, changes a variable or something, and then Home Assistant detects that? I was wondering about that also. Quote
IndyMike Posted December 12 Posted December 12 (edited) You are correct that there is no direct method to detect a "fast on" in home assistant. @Guy Lavoie's technique is the best way of informing HA of a fast on event. EDIT: Incorrect - See @shbatm response below Fast on events will always send a device to 100%. If your normal On/scene operation is less than 100%, you can trigger on the 100% level as a FAST ON. Using the "entity" trigger, the following will interpret a 100% ON as a fast on. The 100% level is 255, so you are testing for something above 254. Yaml: alias: Test Fast ON description: "" triggers: - trigger: numeric_state entity_id: - light.bsmt_fam_cans attribute: brightness above: 254 conditions: [] actions: [] mode: single Edited Friday at 12:13 PM by IndyMike Quote
shbatm Posted December 12 Posted December 12 (edited) Use an event trigger to pick up specific commands (independently of the device state) triggers: - event_type: isy994_control event_data: entity_id: light.main_bathroom_recessed_left control: DFON trigger: event Example Blueprint: https://gist.github.com/shbatm/5b48d2272fb136557ac9b77d2de1beb3 Docs: https://www.home-assistant.io/integrations/isy994/#handling-insteon-or-other-isy-control-events Edited December 12 by shbatm 1 Quote
