Insteon Fast on/off in Home Assistant?
3 hours ago, larryllix said:
..... XXX is switched Fast On
.... do the deed
This is also sent by the non-Dimmer Insteon Wall switches
I know how to use fast on/off on the isy.  I'm asking how to use it in Home Assistant.  In HA there is no option that I can see that detects when an Insteon dimmer is switched fast on/off.
I know nothing about Home Assistant, but if there is no built-in way to detect that command, could you do through an alternate way, using a ISY program that detects it, changes a variable or something, and then Home Assistant detects that?
I was wondering about that also.
You are correct that there is no direct method to detect a "fast on" in home assistant.  @Guy Lavoie's technique is the best way of informing HA of a fast on event.    EDIT: Incorrect - See @shbatm response below
Fast on events will always send a device to 100%.  If your normal On/scene operation is less than 100%, you can trigger on the 100% level as a FAST ON.
Using the "entity" trigger, the following will interpret a 100% ON as a fast on.  The 100% level is 255, so you are testing for something above 254.
Yaml:
alias: Test Fast ON
description: ""
triggers:
  - trigger: numeric_state
    entity_id:
      - light.bsmt_fam_cans
    attribute: brightness
    above: 254
conditions: []
actions: []
mode: single
Edited by IndyMike
Use an event trigger to pick up specific commands (independently of the device state)
triggers:
  - event_type: isy994_control
    event_data:
      entity_id: light.main_bathroom_recessed_left
      control: DFON
    trigger: event
Example Blueprint: https://gist.github.com/shbatm/5b48d2272fb136557ac9b77d2de1beb3
Docs: https://www.home-assistant.io/integrations/isy994/#handling-insteon-or-other-isy-control-events
Edited by shbatm
      37.2k
      372.3k
