December 28, 2024Dec 28 OK. I thought I got it all going, but I am at the point where I can see all my zones in the UI, but status is not updating even if I click Query. And can't control when I press On or Off. What am I missing? TURNS OUT I NEEDED TO CLOSE AND START THE AC TO GET IT WORKING PLEASE I spent two hours on this tying everything and reading the forum topics to incrementally get this working. Please update your documentation so we don't have to go through all of the discussion topics to see what really needs to be done. If a user is having problems, others will also. Please please. Thanks. Edited December 28, 2024Dec 28 by glenn_steiner fix found
December 28, 2024Dec 28 Solution That goes for most plugins where you configure it by making parameter changes or doing some type of discovery. You need to exit the admin console and log back in to see the results.
December 28, 2024Dec 28 Author 6 hours ago, Guy Lavoie said: That goes for most plugins where you configure it by making parameter changes or doing some type of discovery. You need to exit the admin console and log back in to see the results. Yep. I am new and learning the hard way. I spent years writing software and documentation. A minute extra spent by a developer in clearly writing documentation can save a collective group of users hours.
April 13Apr 13 On 12/28/2024 at 4:16 AM, glenn_steiner said: OK. I thought I got it all going, but I am at the point where I can see all my zones in the UI, but status is not updating even if I click Query. And can't control when I press On or Off. What am I missing? TURNS OUT I NEEDED TO CLOSE AND START THE AC TO GET IT WORKING PLEASE I spent two hours on this tying everything and reading the forum topics to incrementally get this working. Please update your documentation so we don't have to go through all of the discussion topics to see what really needs to be done. If a user is having problems, others will also. Please please. Thanks. I don't get a screen like this for zone. I get the below screen. Is this something that change going from 4.x to 5.x versions of the NS? I would like to be able to turn off and on but it just has a Start botton with times to pick and Start with 0.000 is Off.
