HA integration broken after upgrade to IoX 5.9.1
Go to solution Solved by vbPhil,
I upgraded to EISY to OS 14.1p6 and IoX 5.9.1 and the connection to HA is broken. Has anyone else encountered this problem? It seems that HA can no longer connect to EISY. Has something changed in the TLS support or the HTTP: support?
Mike
27 minutes ago, Guy Lavoie said:
What is the HA access to eisy configured as? if it's something like ...@eisy.local, try changing it to  ...@<ip address>
I've tried - http://192.168.1.83:80, https://192.168.1.83:80, & https://192.168.1.83:8443. I know the IP address is correct by checking my router. I also know the IP address changed after I did the EISY update so the router thinks it is a new device (normally my router keeps the same IP address for devices it already has seen in the past). The HA documentation says to use http://.... so perhaps it doesn't support https://..  Perhaps something changed in the EISY support of http:// ?
If someone else has it working with the new release that might point me to my problem.
Mike
I think it's likely that the OS update did do something to confuse/break HA's ISY integration.
In Home Assistant, go to Settings->System->Logs and see if you can find any error messages related to the Universal Devices ISY/IoX integration. If you do find something, you can go here and start a New Issue to see if the author can fix it.
-Randy
For what it's worth I'm using Polisy with Home Assistant and didn't have any issues after updating to 5.9.1.
There's not much to adjust in the ISY Integration configuration. Perhaps there's an issue with the TLS version in EISY?
My ISY Integration is using this IP address with Polisy:  http://192.168.1.50:8080
Problem fixed. I had to connect to port 8080 to get it to work. I suppose that should have been obvious but I found another post about migrating to Policy breaking HA integration and followed that suggestion. I deleted the ISY integration in HA and it found EISY at it's new IP address with the port 8080. When i re-added it all of the previous 'entities' remained the same except the Z-Wave entities. I had to go back and update the HA integrations for the Z-Wave entities and they work now.
Thanks for the responses.
Mike
Looking at the IoX Configuration on the Polyglot V3 web page I get the settings that IoX is using, except the IP would be different from what is shown on this page.
