Yolink v1.0.15 will not install
I had a notification that v1.0.15 was available, Clicked upgrade on node page. When Yolink restarted it displayed 1.0.15 for a second then reverted back to 1.0.4 which was the version I was on before updating.
Let me know if you need logs.
-Tim
@TJF1960 what device are you running and what Firmware are you currently running? There were some earlier posts that 5.8.1 and some underlying PG3x versions were having issues updating. Those seemed to have been fixed in 5.9.1 release and device OS update, but not sure what device you're running on to just suggest updating to get this to update.
Also, are you sure it's 1.0.15? I think you might mean 1.4.15. That's showing the current version on the Polyglot page. My eisy is currently running 1.2.7 of the YoLink plugin. I tried an update earlier and it won't go. I haven't yet updated to 5.9.1.
I can't believe I did not include that info, my apologies.
I am on 5.9.1,
You are correct, Yolink v1.4.15
Sorry,
-Tim
8 minutes ago, TJF1960 said:
I am on 5.9.1
Interesting. I thought others commented that after update it did properly update the plugin. I know @Panda88 said in another post that he's traveling so might not get a reply from him right away, but sure he or somebody will post about their update story.
Perhaps try a power cycle of the device, but if you don't want to then hang on until @Panda88 can give feedback. I might suggest changing the log type to "debug" then perform an update process then maybe a plugin restart to catch any errors. Allow a few minutes for the plugin to stabilize then download the log package. PM the log info to @Panda88 in order to possibly give more data points to review. (Be sure to change the log level back to info or warning.)
Thank you for the help. I will not have time until this coming weekend. But I will post results.
Thanks again!
-Tim
mine upadated after waiting for 5.9.1, it would not update before that....
Try to run the update once more.  The send me a full log with debug enbled.  I do expect it is some missing file - note the installation is handled by PG3 and not the node itself
I have some time in a plane thursdy
