Thermostate with Humidity Sensor Error Reading
bktong
All,
FYI. I have been working with Michel offline for the past few days. I granted him access to my ISY. We have determined that my PLM is NOT sending acknowledgment when a manual query is issued. This only happens when the Thermostat Mode is on Program Auto or Auto. For the rest of the other modes such as Off, Cool, or Heat, manual query is fine and the PLM is able to get the correct acknowledgments.
I will replace my PLM 2412S and of course will do more testing.
Billy
Billy/Michel,
I tested your proof (Billy) and you're right. When my upstairs thermostat is in Program Auto and I perform a query, I get 144%. When I put the upstairs thermostat in any other mode, I get 3%.
Now why I get 3% when I should be getting something more like 43% is another story...?? But I also don't have the humidity dongle, so maybe I should just be ignoring this reading altogether?
Reason I bring it up is because I have another thermostat downstairs, also without the humidity module, yet it reads the correct humidity all the time, in any mode (presently at 45%).
So riddle me why the downstairs thermostat returns the correct humidity while the upstairs doesn't?? Thoughts?
(BTW - incorrectly reading upstairs thermostat takes 2 hops to the PLM, while the correctly reading downstairs thermostat takes 1 hop to the PLM, according to event viewer. if that makes a difference)
Maybe I should have just removed my last post. I'm a moron. I actually have a humidifier connected to my downstairs HVAC, but as it has manual dial controls on it, I wasn't thinking that it could possibly be reporting humidity to the downstairs thermostat. And I don't have the Venstar humidity module either, so methinks now that the humidifier is actually smarter than I gave it credit for and is actually reporting humidity to the downstairs thermostat.
That would also explain the 3%/144% reading on the upstairs thermostat - there's no humidity module OR humidifier upstairs. So that's why I'm an idiot.
I just bought two humidity modules so I expect the downstairs t-stat to continue reading accurately, and the upstairs t-stat to at least be giving me ambient humidity once I install the module there. Am I getting this right?
Hi kaplansa,
Yes, you are correct. Once you install the humidity modules, you should be able to get humidity readings for both of your thermostats. The only word of caution is that only the 7 day programmable thermostats supported humidity (as far as I remember).
All,
After months of exchanging out hardware and software upgrades, we have finally found the cause of the problem. It was due to either a bad PLM (2412S) or incompatibility of PLM version to the thermostat T1800 V2.
I replaced with 2413S.
Thanks for Michel and the UD team. I think we all have learned a lot from this experience.
Now, I can get correct humidity reading every time.
Billy
  • 9 months later...
All,
I have had the same issue, one thing that I tried was to select "cool" instead of "auto" and the problem clears. Once I select "auto" again then I get a humidity value to be double the cool temp setting.
Greg
Isy-99i 2.8.16
T1800
All,
Greg
Isy-99i 2.8.16
T1800
Same here. I get humidity value twice the cool setting when I do a query. If I don't do a query I never get automatic humidity updates. This is with the new v.22 adapter. I gave up on it and removed the humidity sensor.
Hi Greg,
What is the firmware version of your thermostat?
Michel,
It is a Rev. 2.2, it is the integrated 7-day thermostat.
Greg
I also have the new 7-day integrated thermostat w/ the humidity module. My thermostat is rev 2.2 build 1810. I checked and my humidity is being correctly reported regardless of Thermostat Mode.
However, I am not receiving updates from the thermostat automatically and have to use a program to poll it every few minutes to catch changes. I am running 3.1.6.
The automatic updates for humditiy don't work with the new thermostat adapter (V2.2) for the T1700 thermostats either. Also, a query sometimes returns a humidity value of twice the cool setpoint.
Michel,
Update:
First one still has issues in Auto mode with humidity sensor.
Upstairs unit
V2.2 Build 1310
Receive new thermostat for downstairs unit today and it appears to work perfectly with sensor (removed humidity sensor from upstairs unit).
Downstairs unit
V2.20 Build 4010
Set upstairs in auto and it reports humidity as double the set cool temp
Bad thermostat firmware version?
Greg
Michel,
Since receiving a replacement T8000 Rev 2.2, build 1310 adapter a couple of weeks ago, the only time the Tstat reports humidity now is during the regular 3:00 AM Query. The Tstat with the previous rev 2.0 adapter frequently reported Humidity (often too frequently).
Thanks, Michel. I was wondering about the rev 2.2 build 4010 version of the thermostat adapter reported above and if it may have included the humidity reports that used to be sent in rev 2.0. I'll look forward to testing your next release.
Hello wrj0,
As far as I know humidity reporting is disabled by default. And, you cannot set this setting if you have a thermostat without a sensor. And, finally, there's a known issue with the current thermostat firmware to report humidity x 2.
Hello wrj0,
Correction: humdity reporting Cool Setpoint x 2
Thanks, again Michel. Not trying to get under your skin, just wanted to report my observations.
I do indeed have the Humidity Module installed in the T1800. And, the HUM/NOHUM jumper in the T1800 is set to the HUM position.
Previously, when the rev 2.0 Insteon adapter was connected to the T1800, frequent humidity updates were received, as observed on the Thermostat page in the ISY Admin Console, and in the ISY log. With the Rev 2.0 adapter, anytime the humidity value changed, the ISY log recorded a Thermostat, Humidity, value, time stamp string. However, since installing the Rev 2.2 (build 1310) replacement adapter, it now appears that the only time Humidity reports are received is when a query is performed. Since an update to ISY rev 3.1.6 was performed about the same time as the new adapter was installed, my question really was if the Rev 2.2 adapter was causing the humidity reports not to be sent. It appears so. In looking into the ISY log from before the change of adapters, I find that with the rev 2.0 adapter, humidity reports were being received several times every hour throughout the day. But, after connecting the rev 2.2 (build 1310) adapter, humidity reports are now only received after a query.
Please note: with a rev 2.2 (build 1310) Insteon adapter, I have not observed the double value humidity as Pgeengr reported above with his rev 2.2 (build 4010) adapter.
Hello wrj0,
No problem at all. Yes, with new INSTEON firmware, there's an option to send humidity reports (instead of having to solder something). We added support for it and just waiting for verification from SmartHome on the correct bit to set (bit 2 or 2nd bit = bit 3).
      379.9k
