pyschlage library expanded?
Good morning @Goose66  I was just reading about the plugin issues related to library version and supporting python version required to run it.  That prompted me to look at the public documentation for pyschlage.  I notice some methods that may have been added at some point.  With these methods (if I read correctly -- big if) could we possibly now detect unlock events and quickly get the user that unlocked it?  for example method below.  Thanks!
lasspyschlage.log.LockLog(created_at: datetime, message: str, accessor_id: str | None = None, access_code_id: str | None = None)
A lock log entry.
access_code_id: str | None= None
Unique identifier for the access code that triggered the log entry.
accessor_id: str | None= None
Unique identifier for the user that triggered the log entry.
The time at which the log entry was created.
message: str
The human-readable message associated with the log entry.
Unfortunately the newer versions of the pyschlage library require Python 3.12 or better. The latest eISY/Polisy firmware has Python 3.11. I don’t believe we can use the newer versions of the pyschlage library.
Thanks. @Goose66 I suspected that it would not be until python was updated on eISY. However, once/if that occurs, would the newer library provide features like detection of who just unlocked the door?
Going into an area I don’t know, do you think/guess will it be possible to use the updated library from another box like rpi or on eISY once the HomeAssitant extension is released to leverage those features?
I don't think retrieving the log entries is new - it appears available in the version of the API we are using. What is new since the last time you and I talked about adding this feature is the ability to pass both timestamp values and a string value to IoX with state (driver) changes to display in the Admin Console and the UD Mobile app. So we could conceivably parse the latest log entry from the API and add these two states to the node in IoX.
However, this would be for display only. You couldn't really write programs for this, unless the "unique identifier" for the user could be reduced to a, say, 8 digit hash value that you could compare in program code?
Edited by Goose66
Thanks. If we get to that point, does it look like access_code_id could be used in programs to identity the code used to disarm?
So something like this:
Last Access Time: 2024-12-26 08:05:56
Last Access #: 63824331
Last Access Message: Unlocked by Access Code
You would have to do some testing to learn what hash codes go with what access_ids, unfortunately. The Last Access Message may contain the text name associated with the access_id, but it seems like we looked at this before and that wasn’t the case. Perhaps I can retrieve the text name and append it to the message, e.g.:
Last Access Message: Unlocked by Access Code: Goose66
Edited by Goose66
That sound good! As we discussed in the past (can't find thread or DM but recall the exchange), the ability to catch the unlock event and the Access Code (not the actual number but a representation) would be a great feature for me.
With the Schlage ZWave locks these WiFi versions replaced I used a UserNumber and with that via a program then sent a Disarm security command via Envisalink (likely using NodeLink at that time).  I had a user on the lock with the Distress Code so that code could be entered on the lock to send through as Distress code to alarm monitoring.  This was a big plus when having hands full coming in door located near alarm keypad and even greater to allow entry though doors not near the keypads.
You must remember that the state here is refreshed by polling of a cloud service like every 20 seconds or so, or every minute if there’s been no activity for a while. Your not going to be able to disarm an alarm system on unlock unless it can be disarmed up to a minute after the code is entered in the lock.
What’s more, if you turn up the frequency of polling, Schlage may end up rate limiting requests or even blocking access for all users.
Thanks. I could use the alarm open zone via envisalink-DSC because the doors I open are entry delay so could catch that to force update and then get the user.
Great, thanks. Let’s see if UD upgrades the python library. If not, is it possible I could use HA(potentially on eISY) to implement this functionality?
  • 2 months later...
@Goose66 , I contacted the pyschlage library creator David Knowles via email about needing Python 3.11 support. He asked me to enter an issue in GitHub. I did and a couple hours later he marked it as closed and I can see activity on it. It’s issue 259 here https://github.com/dknowles2/pyschlage/issues/259.
Once this is officially a release, can we explore options we discussed in this thread?
1 hour ago, Goose66 said:
We don't need an updated version of the pyschlage library to implement this functionality, so I went ahead and rolled out a new version 3.2.4 using the older library that adds the requested functionality. Let me know if it works for you.
Great!  I'll try it out when it shows up to install.
@Goose66 , this is fantastic! It worked as wanted and expected!
Following are two test programs that uses Schlage Encode opening to disarm DSC Security system via your very own EnvisaLink-DSC.
Garage:Entry Delay Disarm With Schlage Code - Catches Entry Delay so it can Force Update
'Security System / Security System:Partition' Partition State is Entry Delay
And 'Security System / Zone:Interior Garage Door' Zone State is Open
Set 'Garage / Garage Door' Force Update
Garage:Internal Deadbolt Unlocked By User 1 - Catches user that opened Schlage deadbolt so we can use their code to disarm alarm panel*
'Garage / Garage Door' Last Access Code Used is '$Security_Code_User_1_I User Number'
Set 'Security System / Security System:Partition' Disarm USER CODE*
*Now that part about disarming with user code of person that opened Schlage Encode deadbolt takes us back a couple years to a request for EnvisalLink-DSC. https://forum.universal-devices.com/topic/41353-disarm-with-multiple-codes/ So as not to break for anyone, could we set if USER CODE is not supplied it continues to use the one in the params?
Again, thank you!
Edited by hart2hart
 Thank you @Goose66 for updates to Schlage and EnvisLink-DSC plug-ins.  Now unlocking the door can use a code to disarm security.  Great when you have your hands full coming into the house!
Using Entry Delay worked great to trigger Force Update instead of lowering short poll which would potentially cause issues.
