Arithmetic calculations
How do I perform simple arithmetic on several integer variables with the result assigned to a new variable?  For example:
$TempGradient = $inside temp - $ outside temp
Solved by paulbates
Results are always assigned to the variable register they originate from.
Try not to use STATE variables for complex calculations as they may trigger your dependent programs repeatedly with premature results. For multiple operation calculations, it may be best to use an Integer variable and then transfer the resultant into the STATE variable.
Use of a lower precision variable, during calculations,  will result in truncated decimal places for the final variable precision regardless of the final variable set precision.
Hmmm.  I looked at the ISY manual but it's not clear.  I am using integer variables. in a program, I assign an integer variable (X) the result of a sensor temperature outside the house.  In the same program, I assign a second variable (Y) the result of a temperature  inside the house from a separate sensor (thermostat).  What I want to do is get the difference between the 2 variables (Y -X) and assign that to a third integer variable (Z).  Then, if the difference is greater than 15 degrees F, the program turns the furnace on.
It will take to statements to get the total in the variable:
$TempGradient -= $outside temp
The -= means subtract $outside temp from $Tempgradient.
$Tempgradient has to be a state variable, as is any variable that is used in an If statement
Edited by paulbates
I see.  Thanks.  Works perfectly.
