June 11Jun 11 A couple of years back I set up 2 Insteon Contact sensors (2843-222) in weather tight boxes to monitor my 2 gates. They seem very intermittent. They work and don't work. I get heart beats every few weeks. I have dual band insteon modules in the house about 20 feet away that should pick up their signal. I have been looking for an alternative solution and found these. https://www.lowes.com/pd/Ring-Pre-Sale-Ring-Alarm-Outdoor-Contact-Sensor/5005824673?user=shopping&feed=yes&srsltid=AfmBOopmSVTYsEsUk-P-iszna3iiuBYXmubzUYcXiUaw0BlRxyGL-zvL_Q8&gQT=1 This is a Zwave device. I have many Zwave devices. I setup the Polisy to register this device, and it did. Polisy picked up 7 entities. Unfortunately non of them pick up any activity. The device seems to be working. It has a tamper LED which seems to work. I am testing this device 10 feet away from the Polisy. Has anyone tried this? Maybe some idea on a different gate sensor?
June 11Jun 11 Insteon wireless heartbeats are sent daily. Your results of weeks between heartbeats say that the contact sensors are in a box that is shielding their rf, and/or They are far away from the PLM or nearest dual band device Do you have an insteon lamp or on/off module you could temporarily plug between where the sensors are and the house powerline to test this theory?
June 11Jun 11 Author @paulbatesI will try this. I have an outlet under the eve which is line of sight to the gate. My bathroom is 15 feet from my south gate sensor. There is a 1/8 inch glass window in it. In the bathroom is a Insteon lamp module and a insteon wall switch. The sensor is mounted in a thin plastic weather tight box 4 feet from the window. Sometimes I may get 5 or 6 heart beats a week, but not often.
June 11Jun 11 4 hours ago, CPrince said: Unfortunately non of them pick up any activity. The device seems to be working. Since these are "Ring" branded items it might only work (well) with the Ring Alarm system. It might be connecting to the Polisy Z-wave controller, but the Polisy doesn't know how to handle the sensors. From the product page you linked to: Quote Requires Ring Alarm or Ring Alarm Pro (sold separately). Sounds the siren on your Ring Alarm when armed and triggered. You would probably want/need something generically branded for z-wave to possibly work. Otherwise, I think @paulbates has a good idea of moving something closer to the Insteon sensors. It is possible you are beyond range (or very limits) even though the box they're in is "thin". The signal still has to go through walls/boxes and "stuff" that can really kill the RF signal. I'm not sure how others have handled gate setups, but know several have talked about it in the past. Perhaps a Google Site Search might help find some older threads.
June 11Jun 11 6 hours ago, Geddy said: I'm not sure how others have handled gate setups I'm not suggesting abandoning Ring or Insteon sensors just yet, but I've had a lot of success integrating outdoor sensors to eisy via Yolink devices. The LoRa technology works great over long distances, battery life is outstanding, and the Yolink plugin for eisy works quite well (the developer has been very responsive to requests and feedback via the forums). I also have a ton of Ring devices but I prefer Yolink for anything where distance is involved. For example: I have a Yolink contact sensor inside a mailbox about 150 yards away to detect when mail gets delivered, with a hilly terrain and lots of trees in the line of sight, and the sensor is rock solid. I suspect one of their contact sensors would work quite well for gates. If new to Yolink, one would need a hub, but the starter kit cost for a Yolink speaker hub plus two outdoor contact sensors is pretty reasonable at around $65 (the speaker hub adds a nice dimension by providing the ability to easily integrate custom audio alerts). And it just reliably works without a lot of hassle. Edited June 11Jun 11 by dwengrovitz
June 12Jun 12 I have a Yolink sensor installed on my metal mail box: https://www.amazon.com/Universal-Contact-Closure-Assistant-Security-Required/dp/B08P1VQMCR/ref=asc_df_B08P1VQMCR?mcid=b0c7c452897c36e98dc5936b3338999c&hvocijid=1587467274128929744-B08P1VQMCR-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=1587467274128929744&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004510&hvtargid=pla-2281435179058&th=1 Long range and long battery life. There is a plugin to bring it in to UD infrastructure.
June 12Jun 12 Author @dwengrovitz Thanks for the YOLink tip. I ordered the starter kit last night as suggested. 1/4 mile range; impressive. 5 year batter; nice. I will work on the Ring Gate sensor on the side. There is a uTube video on how to connect it to Home Assistant. Just for the record, I have ordered all sorts of Zwave stuff on eBay. Most of the Zwave stuff works as expected. The only thing that I have given up on is "The Button". I like going outside the box. Thanks @DennisC. I have ordered it and have a weekend project!
June 12Jun 12 37 minutes ago, CPrince said: 1/4 mile range; impressive. 5 year batter; nice. I have yolink too and it is a great compliment to insteon on a UDI system. I don't have the contact sensor but the devices I have all function as advertised.
June 12Jun 12 9 hours ago, CPrince said: There is a uTube video on how to connect it to Home Assistant. There are lots of fun options to play with if you also have Home Assistant. Take a look at the Ring MQTT add on in HA as it lets you integrate most all of the Ring ecosystem into your home automation setup (including contact/motion/flood sensors, smart lights, keypads, etc.). And Yolink also plays nicely with HA via an integration. Definitely sounds like you have a weekend project coming up.
June 14Jun 14 Author @dwengrovitz@paulbates @DennisCHey guys. My starter kit came to day. Thanks for the tip. I have reviewed the quick setup. This is new to me. Before I get folks telling me "you did not need to load all that"... Do I need to load the app? I figure this is the only way to to setup WiFi. I found the Poligot plugin; but waiting to install it. Looking for tips on setting this up. Thanks in advance!
June 14Jun 14 6 hours ago, CPrince said: @dwengrovitz@paulbates @DennisCHey guys. My starter kit came to day. Thanks for the tip. I have reviewed the quick setup. This is new to me. Before I get folks telling me "you did not need to load all that"... Do I need to load the app? I figure this is the only way to to setup WiFi. I found the Poligot plugin; but waiting to install it. Looking for tips on setting this up. Thanks in advance! By app, if you are referring to the Yolink app, yes you need to install the app. The Yolink app is the way to interface with Yolink devices. You will also need it if you add the Yolink plugin to eisy/Polisy. The codes required for authorization come from the Yolink app.
June 15Jun 15 Author The Yolink works nice. Easy setup. The outdoor gate sensor has a nice case. Just wish it had screw holes to mount. I will probably mount in my existing box and use my existing gate contacts. Thanks for the tip.
June 18Jun 18 Author Just for the record, I found out why these Insteon open/ close sensors (2483-222) are so flaky. The batteries were dead. But let me explain. I put lithium energizer batteries in, in January. They were dead in March. I figured the cold took them out. So I put Duracell batteries in, in March. They were dead in June; go figure. So maybe they were struggling to communicate with my Polisy putting the batteries under extra load?
June 19Jun 19 15 hours ago, CPrince said: So maybe they were struggling to communicate with my Polisy putting the batteries under extra load? Hot and cold temps are a factor... but my experience with those is the frequency of activation... the more they're used, the faster the batter dies. My experience with these and Insteon motion sensors is that when the batteries run low or dead they get flaky, it helps to factory reset them and right click on them in iox and pick restore device.
June 29Jun 29 Author Update on the Z Wave Ring Outdoor Contact Sensor ver 2. It is as Z Wave as they come. I put a Zooz 700 dongle in my Home Assistant. Then I added the Ring contact sensor. The only difference was Home Assistant asked for the PIN which is printed on the device and Polisy did not. So if you have these laying around you can put them to use with Home Assistant. Maybe someone will come up with a Polyglot plugin for Ring?
June 29Jun 29 46 minutes ago, CPrince said: Maybe someone will come up with a Polyglot plugin for Ring? There is one in the production store, I've used it for several years though I use it on an older doorbell. Ring zwave devices are compatible with their app/api, which the current plugin uses, when you use their alarm system base station as the zwave host, not the zooz stick. You can find its support section on the forum and ask there about support for this device, what's possible etc. Chances are it will require you using their alarm system base station Edited June 29Jun 29 by paulbates
