X-10 Devices Stopped Working With EISY.
1 hour ago, RonnieB said:
Hi Dennis,
Yes the PDF refers to a "set button" which is non-existent on any of my Insteon Devices. That's my problem. How to add an Insteon Device to my Eisy without a "set button".
If you follow the link to the manual and look at page 3, there is an illustration that shows you where the set button is. Continue on to page 7 for the written instructions.
All Insteon devices have set buttons. That's how they begin the linking process.
While wiki the information is old it still somewhat applies to the current day controllers. Here's the information about linking devices:
https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Link_Management_Menu#Start_Linking
You can also review in the ISY Cookbook that can be downloaded from the wiki. It too was written for older controllers, but still applies for most general Insteon setups.
Manual for the 2663-222 device attached. Since it has two controlled outlets. It has dual buttons. The 2473 is has a single controlled outlet and I see the quick guide  was provided to you.
See the full users manual for details.
2663-222-en.pdf
Edited by Brian H
