RF_Burns Posted June 18 Posted June 18 My programs stopped working. I pulled up the ISY admin console and found the ISY could not talk to any devices. The ISY was talking to the PLM however (Checked status). We are going away for a month starting this weekend, so I purchased a new PLM and backed up the ISY. Installed the new PLM following the instructions here: https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:File_Menu#Replace_Modem_(PLM) When I logged back into the Admin Console, the ISY tried reading the Devices and on each one it did an update before (or after) posting an Error that it could not communicate with the device. So when it was done, and all devices showed a communication error, I did a Restore Devices. This only displayed a couple of devices before quitting the routine. The ISY still cannot talk to any devices. Unlike a previous user with a similar problem back in May, I did not change computers... same laptop I have been using with the ISY for years. I can still see all my devices and thankfully they can still talk to each other directly. I'm using firmware 4.8.0 which has been working great for a 5 years, so didn't upgrade. I've had Insteon and ISY for about 20 years and I was in electronics for 40 years, so I'm not a newbie. But Chemo has left me with some brain fog so small technical details elude me. Anyone who can point me in the right direction would be appreciated. Thanks. Bruce Quote
paulbates Posted June 18 Posted June 18 A possibility is that the PLM was so far gone that when you backed up, you backed an empty and/or corrupted PLM data table.... and that's what was restored. Do you have a good backup from before the problems started? Restore that and then restore the PLM, retest Quote
RF_Burns Posted June 18 Author Posted June 18 Thanks for that suggestion. I have one from last September that I just tried. It got to the 13% point and then failed with the error: Could not open file /conf/network.cfg Failed resetting the PLM -200000/-30 hmm Quote
paulbates Posted June 18 Posted June 18 (edited) The new plm may have gotten 'confused' by the initial bad restore. I would try: Factory reset the PM: Unplug the plm from the wall, press and hold the set button while plugging it back in the wall, keep holding it until it beeps Unplug the ISY, wait about 10 seconds, plug back in, give it a couple minutes to fire up Try to restore the backup and then restore plm Edited June 18 by paulbates 2 Quote
RF_Burns Posted June 19 Author Posted June 19 Ok, so I reset the PLM and restored from the second from last backup in case it was corrupt. I didn't get the "could not open file" error this time, but still after Restore of ISY and Restore PLM, I still have no communication with any devices. One thing I get after rebooting and logging into the ISY, while trying to read each device the ISY tries to write to it which shows ERR 1 on the progress bar. This takes about 20 minutes to go through all the devices which also shows the error window "can't communicate with device". None of the instructions mentions this is going to happen. Quote
DennisC Posted June 19 Posted June 19 Try plugging the PLM in to a different power circuit in case there is something on that circuit causing interference. Quote
paulbates Posted June 19 Posted June 19 I would also pick a device that's in a scene with several other devices, right click and pick "restore device" Quote
RF_Burns Posted June 20 Author Posted June 20 16 hours ago, DennisC said: Try plugging the PLM in to a different power circuit in case there is something on that circuit causing interference. The PLM is in the electrical closet with about 6ft of wire to the breaker panel. There are also 3 Insteon 2477 dimmers with about 6ft of wire from the breaker panel to them, so no more than 12ft of wiring from the PLM to these dimmers and they do not communicate with the PLM. Another reason I don't believe its noise causing interference is all the devices are programmed to communicate directly and everything that way works. If it was interference, then the devices could not communicate with each other. Quote
RF_Burns Posted June 20 Author Posted June 20 10 hours ago, paulbates said: I would also pick a device that's in a scene with several other devices, right click and pick "restore device" I've tried restoring a single device and all my devices are in scenes, but no luck. At this point, one day away from leaving on my trip I purchased a couple of timer switches so at least my outside lights will come on at dusk and off in the morning. I have bigger issues now. I took the motorhome out for a longer test run and I have some backfiring issues!! I need to concentrate on that problem now ! Such is life! Quote
DennisC Posted June 20 Posted June 20 11 minutes ago, RF_Burns said: The PLM is in the electrical closet with about 6ft of wire to the breaker panel. There are also 3 Insteon 2477 dimmers with about 6ft of wire from the breaker panel to them, so no more than 12ft of wiring from the PLM to these dimmers and they do not communicate with the PLM. Another reason I don't believe its noise causing interference is all the devices are programmed to communicate directly and everything that way works. If it was interference, then the devices could not communicate with each other. This definitely sounds like a nose issue especially given the location you have described. It has nothing to do with communicating directly. Use an extension cord from PLM to another outlet outside the electric room. Also, make sure you have the cable from PLM to ISY connected correctly. If you have another cable, try replacing the cable with the correct type cable. 1 Quote
Guy Lavoie Posted June 20 Posted June 20 How about a simple test for the PLM: try manually linking a spare switch or module to the PLM, just using the link buttons on each device. Just to see if they can talk to each other, without the isy being involved. 1 Quote
RF_Burns Posted June 20 Author Posted June 20 Hi Guys, Thanks for all your help to this point, but I have run out of time. When we get back from our trip I'll revisit this issue. Bruce Quote
paulbates Posted June 20 Posted June 20 Just now, RF_Burns said: Hi Guys, Thanks for all your help to this point, but I have run out of time. When we get back from our trip I'll revisit this issue. Bruce I get it... we spend a lot of our time camping around the Great Lakes, in fact we're out now 😉 Quote
larryllix Posted June 20 Posted June 20 7 hours ago, paulbates said: I get it... we spend a lot of our time camping around the Great Lakes, in fact we're out now 😉 Which Great lake were you in? Quote
paulbates Posted June 20 Posted June 20 36 minutes ago, larryllix said: Which Great lake were you in? Lake Michigan near Petoskey! Quote
oberkc Posted June 21 Posted June 21 16 hours ago, paulbates said: Lake Michigan near Petoskey! I get up there a couple of times each year. Unfortunately, I am stupid and do things backwards. I go south in the summer and north in the winter. We like the good snow at Boyne Highlands. 2 Quote
RF_Burns Posted July 27 Author Posted July 27 So we are back from our one month trip to Newfoundland. Got some Screech and kissed the cod! Interestingly while we were away, I got an Insteon water detector alarm emailed to me. So that came through by Insteon RF connection since that is it's only method of communication the water detector has. So the Insteon modem is talking to the ISY . I took a 8 button switch that is in a desktop case and plugged it into the same outlet as the ISY modem and they do not talk to each other. So I took that 8 button switch out to my shop, so it must talk through 150ft of #6/3 cable back to the main breaker box, then out to the switch it is linked with and I can control the switch... so I'm sure it is out of RF range and must talk through the wireline. Anyone know of a way to check for noise on the power line? Maybe some place I can probe with my scope on the modem or a switch module? Thanks. Quote
DennisC Posted July 28 Posted July 28 You can start here: https://wiki.universal-devices.com/INSTEON_Signal_/_Noise_Troubleshooting https://wiki.universal-devices.com/INSTEON:_Troubleshooting_Communications_Errors Quote
RF_Burns Posted 15 hours ago Author Posted 15 hours ago So, today I killed all the power to my house except one outlet to run the PLM and one keypad in a desktop housing. I ran the ISY and my internet modem from a portable inverter power unit to eliminate their switching power supplies from interfering. So the only thing operating in my whole house was the PLM and the single keypad and I could not talk to that keypad. Interestingly I could push button B,C,D,E,F,G, or H and the ISY would register that it was ON or OFF, but not the main button A (Main) "Cannot communicate". I'm guessing the rest of the buttons it is communicating by RF? At this point I am about to give up. I replaced the PLM, and tried a number of backups. It will not link in a new keypad, so maybe this new PLM is also a dud. Quote
Techman Posted 14 hours ago Posted 14 hours ago By turning off the breakers you disrupted the Insteon powerline signals. Keep in mind that other Insteon powered devices also act as repeaters. The problem doesn't sound like it's with the PLM. Being that some of the buttons worked correctly on the KPL leads me to believe that you have some invalid links in either the ISY or the KPL. If you have the ISY994 then the issue could be with your SD Card. They have a tendency to fail. What you can try is to remove power from the ISY, then remove the SD Card and clean its contacts with a soft eraser, replace it and power up. 1 Quote
