ISY994 sporadically turns everything on
Recently I have started having a problem with my ISY994 sporadically turns everything on and opens the garage door. It seems to be triggered by events like a motion sensor turning on a light or a time of day programmed event. Unplugging the ISY several times has not resolved the issue.
Is it time to replace the ISY994? With what?
Graham
Graham
Sorta sounds like the old Insteon All on event. ISY shouldn't activate devices on it's own.
Plenty of info in the forum and troubleshooting wiki to dig deeper.
If you are looking to update, easy is the most current and only available option.
I've seen mentions of the All On command events, and have experienced one myself. One question comes to mind: since it's a valid Insteon command, is the PLM able to receive and recognize this command? If so, shouldn't IoX give us the capability to look for the reception of an All On command, and allow us to use it as a trigger event, which would allow us to mitigate the effects?
Agreed on it being an "all on". While there's little definitive data, battery devices like motion sensors can be involved... in my experience when the batteries are allowed to die.
If you have a motion sensor where the battery died, or one that seems to be associated with the all on; factory reset it, right click on iox and pick "restore device"
Would an all on also open the garage door?
I have an Alexa sunset routine that turns on six lights. Worked perfectly until recently, varies some come on, none come on, works okay, everything comes on.
Yes. The "all on" is an Insteon feature... It's possible to send a message to all Insteon devices to go on instantaneously. It sometimes happens accidentally. there's actually an "all on" button at the bottom of iox.
How old is your plm? If your don't know for sure, post the 4 digits from the sticker on the back
If you are using an Insteon IO link to control your garage door then it could respond to an "all on" and open the door.
The "All on" issue is something I have not heard about for years.  Search the old threads in here about it.  I don't believe it was ever nailed down as to exactly what causes it and perhaps there is more than one thing.  I don't think it is the ISY that is doing it and I doubt replacing it will fix the issue.  But I have seen where it will mysteriously start, then just as mysteriously stop happening.  I had it happen a couple times many many years ago for unknown reasons and then I haven't had it happen again in over a decade.  I did not have any battery devices at the time.
I assume you are using the most up to date firmware for your 994i.  That unit is no longer supported and the most recent firmware is a few years old.  However, that firmware is very stable.
Edited by apostolakisl
I still experience an occasional fall on event. I have never spent a lot of time trying to isolate the source but suspect it is associated with one of a few motion or door sensors that I have. Yes, they affect IO lincs connected to garage doors.
To Paul all I see is ISY-994i SN 13916.
  1. To the best of my knowledge, Smartlabs HAS NOT removed the all-on command from current PLM's.  They are still capable of sending the command (it is a valid command).
  2. Smartlabs HAS removed the all-on command from some of the newer Insteon modules.
  3. To the best of my knowledge, the IOLinc is STILL SUSCEPTIBLE to the all-on command.
  4. The ISY can still send an all-on command if you wish to test your devices.  Navigate to the "My Lighting" item in the Admin Console Tree and you will see the all on at the bottom of the window.  This will execute the group all on command.  Devices that do not respond have been "fixed" or can't hear the communication.  Devices that do respond are susceptible.
  5. Most of the issues with all on events seem to involve motion sensors, keypads, or devices that trigger programs that talk beck to the same device.  I'm not aware of any specific Alexa issues (but then i don't use Alexa).
The wiki mitigation posted above works reasonably well.
There are Many posts on the forum.  Try searching "site:"forum.universal-devices.com" all-on event"
Best of luck.
Edited by IndyMike
  • Thanks 1
Good information. But if the PLM is also able to recognize the reception of an All On command, it would be great if the eisy could look for it as an "If" event, and we could program mitigation commands for the more critical items.
Sorry, I'm not going to try to re-quote 10+ years of history.  Search the forum's
If it’s all Insteon devices, it’s simple but zwave complicates it a bit. Still doable but not a give me.
Also, didn’t see which isy firmware you are on so may need to move to last versions for it to make the migration to eISY. It is a great upgrade and it’s getting better.
      379k
