Eisy won’t turn on
Bob Amott
I have two polisy boxes. I had both go down at the same time (power glltch?). Re-imaging on SDD fixed one but the other would not. UDI support talked me through  getting anew SSD and that fixed the other polisy. Apparently the polisy units used smaller SSD sizes and that makes them less reliable with less swap and rotate memory bits room.
A USB to mSATA programmer runs about $10 on amazon and a new say 256GB SSD will run you about $40. Programming is quick and easy. After installing it, setup takes a few hours to load in your credentials, time zone, and backup files, and you are away.
It wouldn't be that expensive to create a new SSD and if, not the problem, you would have a backup drive. It sounds like those polisy SSD only last a few years, anyway, from experiences here.
Thanks for the reply. All that is good to know for future storage problems. I'm not sure how any of that will fix the root cause of my issue being the Eisy does not turn on. What am I missing?
You should open a support ticket with UD before doing anything else.
      379k
