Can't create Advance Status Configuration
Hi @Javi,
I can't create advance status configuration for the 4 tiles that have Nano in the description.  No trouble with any other that I know of.  Those tiles are associated with the MQTT plugin.  Maybe that's the issue?
Tim
Solved by Javi
Thanks @Javi,
Here you go:
<profiles>
<profile family="10" id="1">
<files dir="nls">
<file name="en_us.txt"/>
</files>
<files dir="editor">
<file name="editors.xml"/>
</files>
<files dir="nodedef">
<file name="nodedefs.xml"/>
</files>
</profile>
<profile family="10" id="2">
</files>
</files>
<files dir="nls">
</files>
</profile>
<profile family="10" id="3">
</files>
</files>
<files dir="nls">
</files>
</profile>
<profile family="10" id="4">
<file name="udmobile.xml"/>
<file name="hometele.xml"/>
<file name="custom.xml"/>
</files>
<files dir="nls">
</files>
</files>
</profile>
<profile family="10" id="5">
</files>
<files dir="nls">
</files>
<file name="nodedef.xml"/>
</files>
</profile>
<profile family="10" id="6">
</files>
<files dir="nls">
</files>
</files>
</profile>
<profile family="10" id="7">
</files>
<files dir="nls">
</files>
<file name="editor.xml"/>
</files>
</profile>
<profile family="10" id="8">
</files>
</files>
<files dir="nls">
</files>
</profile>
<profile family="10" id="9">
</files>
</files>
<files dir="nls">
</files>
</profile>
<profile family="10" id="10">
<files dir="nls">
</files>
</files>
</files>
</profile>
<profile family="10" id="11">
<files dir="nls">
</files>
</files>
</files>
</profile>
<profile family="10" id="12">
</files>
<files dir="nls">
</files>
</files>
</profile>
</profiles>
</files>
<files dir="nls">
</files>
</files>
</profile>
</profiles>
Perfect, Please post output of these 3 files:
NodeDef, needed to get the editor ID from node def ID:
http://192.168.XX.XX:8080/rest/profiles/family/10/profile/12/download/nodedef/nodedefs.xml
Editor, needed to verify missing min/max or subset values:
http://192.168.XX.XX:8080/rest/profiles/family/10/profile/12/download/editor/editors.xml
Node:
http://192.168.XX.XX:8080/rest/nodes/nodeAddress. where nodeAddress is the node address of any one of the nodes with the issue. Needed to get the Node Def ID
Hi @Javi,
Here you go:
Editor.txt Node Def.txt
n012_sonoff2 is the node:
<nodeInfo>
<node flag="0" nodeDefId="MQSW">
<address>n012_sonoff2</address>
<name>NANO bit0</name>
<family instance="12">10</family>
<hint>4.2.0.0</hint>
<parent type="1">n012_mqctrl</parent>
<type>4.2.0.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>n012_mqctrl</pnode>
</node>
<properties>
<property id="ST" value="0" formatted="Off" uom="78" name=""/>
</properties>
</nodeInfo>
Node Def:
<nodeDef id="MQSW" nls="SWITCH">
	<editors/>
	<sts>
		<st editor="ONOFF" id="ST"/>
	</sts>
	<cmds>
		<sends>
			<cmd id="DON"/>
			<cmd id="DOF"/>
		</sends>
		<accepts>
			<cmd id="QUERY"/>
			<cmd id="DON"/>
			<cmd id="DOF"/>
		</accepts>
	</cmds>
</nodeDef>
Editor:
<editors>
	<editor id="BOOL">
		<range subset="0,1" uom="2"/>
	</editor>
	<editor id="ONOFF">
		<range uom="78"/>
	</editor>
	<editor id="TEMPF">
		<range max="176" min="-40" prec="2" uom="17"/>
	</editor>
	<editor id="HUM">
		<range max="100" min="0" prec="2" uom="22"/>
	</editor>
</editors>
Summary: Editor ID "ONOFF" is missing  min/max or subset
Added pull request for developer
https://github.com/Trilife/udi-mqtt-pg3x/pull/16
