Do we have the new UI on Polisy?
Solved by Athlon
@Athlon correct. The port 3000 should still take you to the PG3 login just as it always has. That is NOT the new UI for IoX. From the eisy-ui release info back in July:
Quote
To launch eisy-ui, point your browser to http://eisy.local and login using your portal username and password.
Last I saw/heard around here was that it was being tested for use on Polisy, but not sure if it would be available. Since it's "eisy-ui" I'm not sure if it's active for Polisy users. That's something UD would need to answer.
More about the eisy-ui is on the wiki:  https://wiki.universal-devices.com/Eisy:User_Guide#eisy-ui
So I thought as well.  The email is a bit ambiguous about that so as a Polisy user I thought I would ask.
The release announcement says Polisy and the install notes say polisy too so I'm presuming it should work. Will update later today....
