Matter for Dummies II ?
I wanted to continue this thread started by Ristin, but its closed ... so Matter for Dummies II is created
I need a Dummies guide to Matter dongle on the EISY.
I have a mix of Insteon and z-wave devices, google home (speaker) and / or Alexa Dot
It would be nice to a comprehensive guide as per UD of how this should all work
You should ask more specific questions. But as far as the ZMatter dongle goes, it has hardly...mattered (bad pun) yet. Matter is based on IPv6 and most line powered devices will be using IP (wifi or hardwired). Battery powered devices will more likely use Thread, which is IPv6 over a Zigbee network. The few tests I have done with Thread were with Nanoleaf bulbs, which use Thread even though they are line powered. The ZMatter dongle (which is ZWave/Zigbee really) is meant to allow direct communication with Thread, as well as conventional Zigbee. But I don't think this has been implemented yet. Instead, UDI has been supporting Thread based Matter through a border router, which is what I did, using a Echo in my case. Border routers are "transparent", simply bridging IPv6 packets, across wifi/hardwired IP and Zigbee networks.
There has been very little in terms of announcements from UDI since the initial release and excitement last spring. But in reading the notes in the sysconfig.txt file of the latest release (6.0.3), some additional Matter fixes were added. I don't have access to that right now, but I've seen some mentions of Matter among the changes.
Thanks for the reply and it seems to be a deep subject ... when I first read the spec on Matter, it sounded very simple in as much ... all these companies signing on to provide one command method of coms across a vast offering of hardware .... but they had to make it difficult :-(
Specific questions, well it's winter here, snow is deep, stuck inside, thought maybe I could play and just maybe, get something working and a bonus would be voice commands
Do you have a Matter device to try? Ideally something that's just on/off like a switch, or light bulb.
I have understood that "matter" is in the early stages for UD and, as such, documentation and user manuals is not something we should expect. I have had some luck with matter devices over wifi, but matter devices over thread have not worked consistently for me. In fairness, the thread devices (nano leaf bulbs) I have tried also do not consistently work with echo or google, either, and am willing to consider the possibility that the problems might be with the nano leaf bulb, rather than with the EISY. I keep looking for other thread devices to try, but I don't see many around.
At this point, I'm not going to invest in a technology which is not reached any industry deployment standard ... it's just not worth it
Maybe I'll spend my time modding an Insteon switch into a laser trip sensor or turn a dimmer into proximity distance switch, something useful -D
But I will keep my eye on matter & UD progression more closely
Edited by jim_
Matter is still preliminary for many companies, not just UDI. The trick is to start small, just to get familiar with it. It's a first real effort at interoperability by home automation companies, so there are lots of players involved. I haven't implemented anything with it yet, but just learning the basic premise has been useful. You commission a device on one platform, then share it. The use of PIN codes or QR codes, etc. The reliability will eventually be there, and I'll then be ready for it.
For the Nanoleaf bulbs, there have been firmware updates, a sign that things are still being sorted out.
About a year and a half ago, I bought 3 Eve Home Energy (Matter) modules (On/Off) to use to control our inside Christmas decorations replacing the Insteon modules I had been using. These Energy modules include a Thread Border Router and after installing all 3, they began to communicate with each other. Some links were weak as they are spread around the house, but they worked. They are as fast as if not faster than the Insteon modules. I have started using Apple TV for my TV connection instead of the cable boxes, so I have several around the house. The newer Apple TV's include a Thread Border Router. I added the Eve Energy modules to Home Kit on one of the Apple TV's and it joined the existing Thread network. Now all the Apple TV's are on the Thread Network. This has given me a very solid network for Matter devices. Initially, I used Home Kit to automate the Eve Energy modules and they have been very reliable. I don't remember the exact release, but it's now possible to join eisy to devices on an existing Thread network using the Set Up code for the device. I did that using UD Mobile. Adding worked as expected. Now I can see these devices in eisy and II have all programming for the Eve Energy modules in eisy. It's working great. I'm sure there's more to come from UD, but there's enough there to get started with something useful.
That's also been my observation: commissioning the device on something else (like Alexa or Google Home) and then sharing to the eisy usually worked. Initial commissioning to the eisy hasn't been very successful.
My experience with the Eve Home Energy (Matter) modules was also very useful. I have a ton of relatively new Insteon switch devices and an eisy hub for lighting control in my house. I also have Home Assistant set up to integrate a lot of non-Insteon devices in my environment, such as a dozen Smartwings Shades (with Matter over Thread motors). For the longest time, I could not get them to reliably stay online, even with their latest firmware update (1.3) which supposedly implemented improvements in that area.
As you mention, the Eve On/Off modules include a Thread Border Router. After I installed a couple of those around the house, my Matter/Thread network and the Smartwings shades have been rock solid. I've also converted a bunch of YoLink sensors to use the local Matter network via their YoLink Local hub, and they have also been rock solid, and maybe even slightly better performing with signaling being local versus using the cloud. I even have a Shelly 1 Mini device integrated through the Matter interface in eisy that I use to control on/off (via an Insteon switch) and scheduling (via an eisy automation) of an old towel warmer device near a shower.
I'm not a Matter/Thread expert, and Matter/Thread is clearly early in its evolution, but I credit the improved coverage and reliability in my environment to those Eve devices.
Edited by dwengrovitz
Can you or is this explained somewhere? How you would set this up. I just installed a TAPO MATTER switch, Connected it to google home I can connect it to Alexa/Amazon if that is easier. but I don't see how I connect that pipe to UD. From google home I see all the other HA systems but UD wasn't listed.
So just trying to understand how to connect Tapo matter switch to UD
Controllers like Google home and eisy don't necessarily "see" each other like that, unless some utility provides that. Instead, you share devices. In Google home (since this is what you have) look for a function to share that device, which will offer you either a pin code or a qr code, that will be valid for a limited time (often a few minutes) that you can then use in UD mobile to add the device to the eisy. Pin codes are easier because you can write them down, while a qr code is an image, which you have to scan ( awkward when you are running both Google home and UD Mobile on the same phone). In testing, I'd save a phone screen shot, email it to myself, open it on my pc, and scan it off the screen with UD Mobile. Hardly user friendly. Now UD Mobile supports entering a Matter pin, much better.
From the google home app, find the matter device you want to share with another matter hub, such at the EISY. Once found, open the device settings (little gear on top right). In the settings, you should find "Linked Matter apps & services". Select that option and you should find another list, including "Link apps & services", in blue font. Select that and you should see a pairing code.
Thanks this is clearer to me now. I was trying to do it from the Java Admin page, not the phone app. Sound like this will work when I get my app working again. Seems when I upgraded everything to 6.0.4 UD Mobile crashes. Don't answer here. I'll open a different post. Thanks
I'm not having much luck, I think I have tried both ways 1) sharing the device by getting the pin code from Google Home, and 2) trying from a factory reset, then adding it in. All using UD Mobile app. I just get errors like Scan already started 500 (OK) or this error. I posted as the image.
NEVERMIND,
I was trying this on the other side of the house. I just factory reset the switch, added it to google home, got the share pin code, and added it to UD Mobile using the code was standing 5 fee away and after about 45 seconds it added it. I think I shot myself in the foot trying it from the office. I though it was all done via wifi where I think it uses Bluetooth for some of it.
I have my switch added -)
