Programs reporting GVx instead of name
Solved by Javi
9 hours ago, apostolakisl said:
There is an update to udx (v4.2.0) that corrects the Elk Plugin from displaying names instead of numerical values in UD Mobile & eisy-ui. It is available from the upgrade packages in the admin console.
Run: https://eisy.local:8443/WEB/sysconfig.txt to check your version of udx. If it is at least v4.2.0, then reboot eisy. After complete startup, synchronize UD Mobile and you should be good to go.
I already have the latest updates.
I have 4.2.0 and have synced. I still get GVx
Do I still need to reboot if I have 4.2.0? Need to upgrade packages?
John
I would suggest upgrading packages to be sure all went well with the upgrade, and rebooting. After everything is up and running (be sure to check all plugins have started - there is a separate issue with plugins not restarting after reboot), then synchronize UD Mobile.
If that doesn't work, I would then open a new support ticket, as something else is going on.
John
I am on 4.2.0 as well. It fixed the similar issue with Elk node not populating, but either created or didn't fix the GVx issue with programs. I don't often look at programs on UD mobile, so not sure when it started.
@Javi
Edited by apostolakisl
