January 11Jan 11 https://1.2.3.4:8443/desc replies "This XML file does not appear to have any style information associated with it. The document tree is shown below."What am I doing wrong? I am trying to start the EISY-UI screens.I want to add some matter devices over thread.I am an old time insteon user and I am having trouble wrapping my head around the IoX launcher/ISY/EISY/EISY-UI/UD-mobile/admin console/portal terminology to keep them all straight.I can't get the IoX launcher to find an hold onto an IoX device to launch an admin console, I have a shortcut on the EISY desktop that launches it. I am an long time C programmer/linux admin and I was expecting to continue to use the admin console but it seems that is being deprecated for the EISY-UI web based app but I cannot get it to start.I got a Thread border router (Ikea device) and expected to add matter devices, and lat time I tried this I found it could not add them because I did not have a TBR but now I do and I cannot find the options to add matter devices.I am confused. there are so many devices interfaces it is unclear which I am using and why I should use one over another.
January 11Jan 11 @S. Alexei Gitter or if your router finds the eisy locally even easier to just type: https://eisy.local/You will probably get a security alert on the browser you're using. You can click advanced and continue to get to the site. Note that I don't think eisy-ui allows direct setup for matter/thread devices. I've not tried it lately. There is a plugin that should help with that, but it's had mixed success and has very limited items for support. I don't use Matter yet so have no experience trying to add devices, but seeing the issues people have on the forums would say don't be too quick to jump on and try to add a bunch of items. As for the Admin Console (via Java) it's still available. What computer OS are you using? It's fairly straight forward (for windows). On macOS it seems to cause a lot more issues. If you're having issues with the launcher finding or keeping the listing you can always save the file locally and load it to have the last list available. Again, seems like it might be computer OS driven issues.
January 12Jan 12 Author I am running the Admin Console on the EISY directlylogin to the EISY as admin -> start.win -> shortcut to the IoX finderthis starts the IoX finder but it never shows any IoX devicesI can add the https://1.2.3.4:8443/desc but even then it does not do anything with thishttps://eisy.local... failsthe Wiki screens show options to start a window or other options but I cannot figure out how to trigger these --- or ---login to the EISY as admin ->start.win ->shortcut to the admin consolethis starts the admin console but I cannot find any options to add matter devicesprior I had an option to add a matter device but I did not have a TBR so it failednow there is a new Matter top level tab but it does not indicate anything about adding devicesSo...I am confused about the use of the IoX finder - any suggestsions about why I would use the IoX finder vs the direct start to the admin console...I am confused about how to add a matter device - any suggestions about where I should post for information about this?
January 12Jan 12 Author also ... I still get the "This XML file ... " text when trying to get to the portal ... I can get to the portal through the internet via my.iso.io but I don't want to get there through the internet, I would prefer to do it locally
January 12Jan 12 2 hours ago, S. Alexei Gitter said:https://eisy.local... failsWhat does "fail" mean?The preferred way to access eisy UI is either:https://eisy.local or http://eisy.localWhat happens when you try these? Note, there is a bug that gives you a blank screen , refresh the page and it should then load.
January 12Jan 12 22 hours ago, S. Alexei Gitter said:the Wiki screens show options to start a window or other options but I cannot figure out how to trigger theseClick on a selection that you added to IoX Finder window. Maybe post screen shots of what you're seeing. 22 hours ago, S. Alexei Gitter said:start.winI'll assume you mean "start.jnlp". There shouldn't be a .win file. 22 hours ago, S. Alexei Gitter said:https://eisy.local... failsThis was meant to be used on a browser. That launches the eisy-ui interface. Attempting to add this in the Java IoX Finder window will NOT work. 22 hours ago, S. Alexei Gitter said:I can get to the portal through the internet via my.iso.io but I don't want to get there through the internet, I would prefer to do it locallyStill possible. Just need to add your device locally. Sounds like you're having issues due to being scattered and trying too much all at once. Pick IoX Launcher and focus on loading that. If you're reading the wiki then it walks you through the process of adding the eisy manually if it isn't found. Are you running VLANs (on your network), anti-virus, or VPNs on your computer?
