Geofence crossed but program does not trigger
Hi,
Both my wife and I have the UD Mobile app installed with our geofences set up. Both are enabled in the app.
I see the phones in the admin console in my Home Geofence node tree. I have the program set up to turn lights on. On isy.com, the phones are also in the Occupancy 2.0 section.
It looks like the app correctly records the time I enter the geofence but the Enter program does not trigger. The program is enabled.
Any obvious reason the program is not being triggered? Could it be that with one phone at home, the crossing of the second phone into the Geofence won't trigger the linked program.
I did notice on the app that under "Devices and Scenes" > "Home Geofence" (with both my wife and I at home) my phone says "false" and hers "true". Is this anything?
Many thanks for your help.
Edited by UD2)17rrh
Further information added.
@UD2)17rrh What phone OS are you running? Be sure location permissions are allowed.
On the geofence do you have it calling on the program or is the program setup for location change? Please post a copy of the program for reference. Be sure you RIGHT click on the program and select "Copy to Clipboard" then paste as text in here. Be sure you use the "COPY" option - should be last option in the menu! (NOT export!)
Be sure the geofence is setup as outlined in the wiki: https://wiki.universal-devices.com/UD_Mobile#Geofencing
Once you have the geofence setup and commands in there you should be able to run the "trigger enter command" to see if it would work.
Where do you see this? I run Geofence options on UD Mobile, but do not have anything related to them in Devices and Scenes in UD Mobile. It must be something associated with Occupancy 2.0. I do not have that in use (It's not needed any longer - according to the wiki).
Thank you for taking the time to reply.
iOS: 26.2
UD Mobile App: Allow Location Access = Always
"Trigger Enter Command": Enter command is successfully sent in the log but the program does not run.
I just noted though, that when I submit the "Trigger Enter Command" in UD Mobile the program in my Admin Console immediately changes to "Disable".
Here is my program:
Geofence Entry Lights - [ID 0007][Parent 0006][Not Enabled]
From Sunset
To Sunrise (next day)
Set 'Gate Lights' On
Set 'Garage Door Lights' On
Wait 10 minutes
Set 'Gate Lights' Off
Set 'Garage Door Lights' Off
Thanks for any further help you can offer.
Ps
I now deleted the phones in Occupancy 2.0.
I have it that the Geofence Entry is calling for the program to run as an Enter Command.
Does it call for "Run If", "Run Then", or "Run Else"?
Given this, the lights will come on at sunset and turn off as sunrise, regardless of any geofence activity.
I do not believe that the presence of one phone inside the geofence would cause the second phone to fail triggering the enter command.
Why do you have a "wait 10 minute" action at the end of the THEN clause?
Next time you enter the geofence, soon check the admin console (or log) and see when this program last ran. Hopefully, there will be a record of the program running at the time you entered the geofence.
This is odd. Are you sure this action is disabling it or do you leave the program disabled? Enable the program in Admin Console then trigger the "enter" again with admin console open to see if it is disabling the program.
Could you post a screen shot of how the geofence is setup? The only way the geofence would disable the program is if you have that as an action on the app. Otherwise, something else in IoX is disabling that program.
It's been a while since I used a program on the geofence setting. @oberkc brings up a good question as to what is being called by the program.
The way you have it written (and it being disabled) depending on when you trigger the program only after sunset would it turn the lights off. Maybe change the geofence to trigger the "THEN" just to be sure that program works to turn those lights on. Otherwise, if you trigger it and it's before sunset then the lights would stay off (because of your ELSE).
Also, I would remove the "wait" line. There's nothing after it (at least not showing in what you pasted).
I haven't setup tracking by more than one phone (we just don't need it for our automation), but nothing you have above would be dependent on which phone crosses. If it's setup the same on both phones to call the same program then if either phone crosses into the geofence they would both call on this program. You might want/need a variable if you're trying to track by phone, but that gets more complicated and involved.
OK. Making progress. So I did see where I needed to change the Command line in the app from Enabled to Run Then. Now when I trigger the entry manually it turns the lights on! Progress.
So how do I make the lights only respond to the geofence command after dark but not come on irrespective of a geofence command at sunset? And is my 10 min wait in the right spot? Just want the lights on until we get in the house.
Edited by UD2)17rrh
The first thing you do is disable the program so that it does not self-initiate. The second thing you do is to add a command after the wait statement to turn the lights off. The third thing you do is change the trigger in your geofence. Tell the geofence to "run if".
"The first thing you do is disable the program so that it does not self-initiate". I didn't think of this as a possibility, thinking a disabled program just wouldn't run at all, but this is a nice feature.
Everything seems to be working as planned now. Thanks again @Geddy and @oberkc.
A disabled program will run if specifically called. In your situation if the program above is disabled and your geofence is set to run the IF (as @oberkc suggests) then it will only evaluate this program when the geofence (entrance) is triggered.
This is typical suggestion for programs that you don't want to run on their own. However, another program calls on the "IF" of the program above it would evaluate the disabled program and run true (THEN) or false (ELSE).
Having the program disabled means it won't run on it's own from sunset to sunrise (next day). But when your geofence triggers the entry area it will run the "IF" line and the result would be to turn the lights on from sunset to sunrise (next day). If it's before sunset then the lights will "turn off" (based on your "ELSE"), but they shouldn't be on so really the else is useless (in this case). If the program is false it just won't turn anything on. If it's the middle of the day though and the lights are on as you have it now the else would turn them off. I would probably suggest removing the ELSE lines from your program.
As @oberkc suggest you need to have the command after the wait to turn the lights off.
I would suggest this as your program:
From Sunset
Wait 10 minutes
Make sure 10 minutes is long enough from when you enter the geofence area though. And sometimes I've been known to have to unload the car and take my time that 10 minutes isn't enough so I'd have to turn the lights on again (manually - oh the humanity!).
Lastly, the program will have the little red circle with a line through it to indicate it's disabled. Due to some issues (in the past) of IoX updates enabling all programs I have added "-d" to the end of my disabled programs. If you wanted to go a step further you could put them in a folder called "Always Disabled Programs" (or just "Always Disabled"). Don't set folder conditions, but just put all your disabled programs in there. That way if there's another update that suddenly enables all programs you know where and what programs should be disabled and can change them quickly. This is just a point of organizing for me and learning from history.
Like @Guy Lavoie Its much easier to have the geofence toggle a variable between 1 and 0.
example variable: Mark is home
Geofence when entered, changes variable "mark is home" to 1, when leaving changes it to 0
The program is then always enabled and the trigger is when " mark is home' =1 (plus your time constraints)
Works very cleanly and is easy to manage and troubleshoot.
@Geddy @oberkc @dbwarner5 These are all really good ideas. Thank you. I've adjusted the original program and it is working well. But I'll try the variable approach as I have a few ideas to expand upon what I am doing now.
Another example is with multiple conditions. I'm often away while the wife is still at home. So if I come home and trigger a geofence entrance, I might not always want it to do something. I also consider if the alarm system is armed. So the trigger becomes:
If geofence = 1
And alarm_armed =1
Then....
In my mind, the variable adds unnecessary complication UNLESS you are trying to track current state (I am currently at home, I am currently away) versus just tracking when one crosses the geofence boundary. Having said this, if one is trying to keep track of a presence (or any other binary-value variable) I suggest considering virtual switches, rather than a variable, to keep track of presence. Using a variable switch adds some convenience to manually changing the presence status should that become necessary (such as when the geofence doesn't fire for some reason).
Clearly, though, there is some use in knowing current state of presence. For example, one might have a program to turn on some lights at sunset, but only if home.
Edited by oberkc
