February 18Feb 18 I brought a 994i unit off of eBay and I'm trying to register it to use the ISY portal. Is there a procedure to do this. I also have an EISY unit that I'm currently using. I had another ISY994i which I sold with my previous house. Any help would be appreciated.I've been able to update the firmware and can access it but that's about it. When I Check the configuration (portals window, it says that it is registered. (Probably to the previous owner)I sent a message off to the eBay seller to see if he could deregister it. Turns out that he wasn't the original owner, so that's a dead end. Edited February 18Feb 18 by JDeRose update
Wednesday at 09:43 PM5 days The ISY994 is no longer supported, so there's no option to update the portal account
Wednesday at 10:00 PM5 days 7 minutes ago, JDeRose said:Seems like they are missing out on an annual revenue stream..The revenue stream is selling a new eisy!
Wednesday at 10:26 PM5 days 30 minutes ago, JDeRose said:Seems like they are missing out on an annual revenue stream..I believe UD made an announcement soon after the ISY994 was no longer supported that the portal would cost more for the ISY994 due to underlying security issues that the ISY994 couldn't work with at the time. I know they raised the price for people keeping a portal account with the ISY994. So marginal additional revenue stream might be overcome by having to "support" the connection from unsupported devices. I think it was even said that the portal couldn't be added to ISY994 devices at one point. So I'm not sure even if it wasn't registered to somebody else if you would be able to add it at this point. Perhaps you could, but UD really doesn't want to keep having to support them with the portal connection. Since the ISY994 works so well off line there's little gained by adding the portal at this point. What is your desired outcome by having the portal connection?
Wednesday at 11:42 PM5 days Author I was hoping to expand my knowledge using the ISY portal and UD mobile but will probably focus on the Mobilinc portal accessfor that unit. I've been spending some time on the EISY Packages and trying different options too.. Haven't been impress with UD mobile but I'm working on it again.
Thursday at 02:04 PM5 days @JDeRose If you have an eisy then I would just use that device to learn about the portal and UD mobile options. For the ISY994 I would suggest just using Mobilinc and using the local connection setting. If you want to open a port on your router you can do that and still access the device with Moblinc, but it's not as "secure" (since you are opening up your network to risk by having a valid port open. I might suggest using a non-typical port number). The ISY994 can work with UD Mobile, but only with 5.x firmware. Again, I'd say probably just use the local connection. If not able to add the portal to the ISY994 you can still use the local connection option. I haven't taken the time to learn all about the UD Mobile options as I don't really need an app. I still use Moblinc with the eisy since it controls nearly everything I have (I'm basically 99% Insteon devices). It's just more comfortable for me and easy to use what I've had for about 10 years now rather than taking time to set up UD Mobile when it's still changing (and randomly breaking stuff) as eisy and IoX continue to evolve.
