Sunday at 04:13 PM5 days Hi, does anyone know if there is a node limit for the KASA plugin? I seem to be maxed out at 20. I had 19 working, added 3 new KASA HS103 from the same 4 pack, and only the 1st unit I setup with KASA app shows as a node. Seems strange it's a nice number like 20 to stop at.
Sunday at 05:40 PM5 days @shawnv not sure of a limit, but if you're not able to get more recognized you can install the plugin into another slot and see if that will recognize the other devices. That might be a workaround if there is a limit. Perhaps @Jimbo.Automates can chime in to advise if there's a limit.
