Program Details Screen
I have just upgraded my ISY994 to an eisy, and I am having minor problems getting everything running the way I thin it should. Specifically, I have a number of programs that while they are indicated enabled on the Summary Tab, when I go to the Details Tab they show up with a vertical red bar on the program icon. I have attached a screen shot. How do I fix this to get the programs running?
1 minute ago, GreyFox said:
The programs with the red bar are not running as scheduled.
Right click on the program name and select "Copy to clipboard". Then post the program here for review.
Be sure to select copy to clipboard.
My time zone is correct, and I have DST turned on.
Here is the copy. Get Ready for Bed - [ID 000A][Parent 0001][Run At Startup]
From 10:30:00PM
For 15 minutes
Set 'Upstairs Guest Bedroom' On 100%
Set 'Upstairs Guest Bedroom' Off
I just replicated your program on my eisy, and it worked fine. I suggest you edit the program, highlight each line and click on "update" as if you were modifying them, and then save the program. Sometimes some things don't migrate correctly like that.
@GreyFox because this program is set to "run at startup" if you reboot your eisy then log into admin console this program will probably usually show the red line.
Here is the reference in the wiki just as information: https://wiki.universal-devices.com/index.php?title=ISY_Programs:Icon_Colors
The only time your icon would be fully green is while it was running the "THEN" portion. After the 15 minuets it should show half green. If you're rebooting your system and looking at admin console before the program triggers at 10:30:00pm then it will be partially red. That doesn't mean it isn't running. It's just the last time the program triggered it was false (and since you have something in the else section it would have run that portion).
So that it doesn't catch your attention you might want to disable the "Run at startup" by right clicking on the program in the summary tab and select "Disable Run at Startup".
You should look at the other programs that show half red in the summary tab to see if the "Run At Startup" column shows "ON" or a dash (-).
If you want to see if the program works then right click the program and select "Run Then". It should turn on your light. But because the "IF" wasn't run it won't turn off in 15 minutes.
If you're still worried that your programs are not running in the Summary tab look at the "Last Run Time" column and see if it's recent. If you just rebooted the device and all your programs are set to run at startup then most all of them should have a recent time run. I should also caution you that if you have a lot of programs set to run at startup you could run a big risk of too much Insteon traffic and create issues for your system. I would suggest limiting only major necessary programs to run at startup and others just allow to run at their regularly scheduled time. You could set the catch up grace period to a longer time if you have a lot of power issues.
As @hart2hart suggests you should review the "Query All" program. Since in the ISY994 that might have been referencing the ISY994 or the name of the ISY994 you had. The Query All program is no longer default on Polisy or eisy systems. You will probably need to update that to point to your new device. The object will be in the "Your Devices" list. Sometimes it is near the bottom as a scene and will have an icon like a computer monitor. Then be sure you save the programs once you make the edit.
