Hello all,
Release 2.8.1 Beta is now available. Although this firmware has been tested thoroughly, please note that this is still a beta firmware.
For a list of changes, please take a look at this post:
http://forum.universal-devices.com/view ... =6475#6475
Please note that ISY-26 is no longer included in the firmware builds.
Instructions
1. Please backup your ISY (File | Backup ISY)
ISY 99 Only - http://www.universal-devices.com/update ... nsteon.zip
3. It is very important that you use your current ISY's Admin Console to perform the upgrade by going to your http://your.isy.ip.address/admin. For MAC users, if upgrade fails, please try https://your.isy.ip.address/admin
4. Login to the Admin Console and choose Help | Manually Upgrade [the name of your system]
5. Choose the file saved in step 2
6. After the upgrade, ISY reboots. Please do ensure to clear your Java Cache:
http://www.universal-devices.com/mwiki/ ... Java_Cache
7. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console:
a. http://isy/admin - applet (Windows only)
b. http://isy/admin.jnlp - Java application (Windows only)
c. http://your.isy.ip.address/admin - applet
d. http://your.isy.ip.address/admin.jnlp - Java application
e. http://www.universal-devices.com/99i/2.8.1 - applet
f. http://www.universal-devices.com/99i/2.8.1/admin.jnlp - Java application
8. IMPORTANT If you have already installed a self signed certificate and your current firmware is 2.7.10 and below, you must reinstall a new one:
http://www.universal-devices.com/mwiki/ ... rtificates
Thanks and with kind regards,
I had a little trouble with my upgrade but I didn't follow step 7 closely.
Clearing the cache and launching the console again the right way and it works nicely.
The In-LineLinc Dimmer can now be checked for On percentage in a program (if you let it autodetect when adding the device).
I do have a question about the Dual Band 240 Load Controller (2477SA2) support. When I add the device I still only see the Control Part. As I understand the 2477SA2 also has load sense capability with links for both On and Off. I have added with auto-detect and manual selection. Am I missing something?
All went will. No problems.
I tried to relink the EZIO4O v.ff but the i2 did not work.
Was hoping to get to the internal timers.
v.ff doesn't seam right but there were no version labels
on the unit.
Gary
garybixler
Whether I2 works depends on how new the device is. Many of the internal PLMs indicate an I2 engine but do not support the ALDB command.
How did you add the EZIO4O, Auto Discovery or explicit Device Type.
If you are on a PC and have a PLM connected to the PC you can use the SHN Utility to configure all the EZIOxx options.
Lee
Lee hi
I did an Auto Discovery.
Maybe will consider an additional PLM for the PC
but it's not that pressing at the moment for timer access.
Gary
You mention support for the 2486SWH8. I have one of these devices and had been using it under 2.7.15 and it appeared to work correctly. Can you tell use what has changed? Should I remove it and add it again under 2.8.2?
Hello all,
If your EZX10RF works, then there's nothing new.
Support for 2486SWH8: did the Admin Console provide you with the correct model number for this devices or did it say Unsupported Device. Furthermore, did you add this device using brute force (in Admin Console the firmware version is v00) or did you use Auto Discovery or Linking?
  Michel Kohanim said:
Hello all,
The admin console reports the correct model number. I added the device using auto discovery. BTW this device was a 2486SWH6 that I converted to an 8-button. In both configurations it was automatically detected correctly with Auto Discovery.
One thing I noticed is that on the Electricity Tab I see a what appears to be an Optionbox on the lower right portion of the screen with a label of "S" (see image below:
Here is a screen shot of my About screen:
I also had this same issue with the previous firmware v2.7.15
when I click on Trend (chart) it gives this error and gets stuck with system busy and a busy mouse icon:
Exception in thread "Thread-22" java.lang.NoSuchMethodError: com.universaldevices.common.ui.GUISystem.getImageIconFromResource(Ljava/lang/Object;Ljava/lang/String;)Ljavax/swing/ImageIcon;
at com.universaldevices.chart.ChartFrame.(Unknown Source)
at com.universaldevices.chart.TimeSeriesChart.(Unknown Source)
at com.universaldevices.ui.report.ReportGenerator.done(Unknown Source)
at com.universaldevices.ui.report.ReportGenerator.access$0(Unknown Source)
at com.universaldevices.ui.report.ReportGenerator$1.run(Unknown Source)
also cancel on tools -> log dialog doesn't work, it reshows itself and after 2nd cancel, it gives NPE
Hi guy,
Are you using Linux and if so, what URL are you using?
I was using local jnlp file
Just tried it with http://isy/admin and http://isy/admin.jnlp and see no errors but graph is always blank
And now even local file doesn't produce any errors (nor graphs), the only change was the changed submenu, so maybe the resaving jnlp helped somehow. I works but it still warns
Could not launch from cache. Will try online mode. [Given JNLP is newer than cached copy!
Thanks[/code]
