Saturday at 06:02 AM4 days it has been more than a few years since I upgraded ISY to its current version is 5.0.16C. Ihelp-> about show that it is ISY 994i (1120)is there a newer firmware that I could use?if so, where do I download it?thanks for any help.
Saturday at 08:53 AM4 days UDI announced that the 994 series was end-of-life almost 3 years ago. If there is newer software, I believe one of the Help drop down menu items would indicate you could upgrade it.
Saturday at 10:54 AM4 days 5.3.4 was the last ISY994i firmware.If you have a Z wave card. Depending on which version you have. Series 300 or 500. 5.3.4 was only for series 500.
Sunday at 03:31 AM4 days Author 18 hours ago, paulbates said:UDI announced that the 994 series was end-of-life almost 3 years ago. If there is newer software, I believe one of the Help drop down menu items would indicate you could upgrade it.looks like I will not be upgrading firmware. I do not have the option to download latest firmware as I am not connecting ISY to the internet. Unless there is a manual download and upgrade option I do not see how can I upgrade it.
Monday at 05:17 PM2 days @iglon do you have z-wave in your ISY994? If not then you can upgrade to the version @Brian H mentioned above (5.3.4). If you have and are using z-wave then which board do you have? See this post from @lilyoyo1 from a few years ago: https://forum.universal-devices.com/topic/29371-zwave-tips-and-tricks/Specifically:DO NOT UPGRADE YOUR ISY PAST 5.0.16C IF YOU HAVE THE 300 BOARD!!! YOU WILL RUIN YOUR SYSTEM!!! If you are not certain which one you have....ASK!!! Its much easier to avoid issues than it is to fix issues simply by asking and verifying.The immediate physical differences between the 2 boards is that the 300 series card has a blue light in the back of the isy while the 500 does not.You don't need to have the ISY994 connected to the internet to update, but it does need to be connected to your network. If you want to update to 5.3.4 (and you don't have z-wave or have the 500 series board) you can get the update from the current release section of the forums: https://forum.universal-devices.com/topic/33287-534-isy994-last-release-for-isy994/ Be sure that you read the post and take precautions to make the backup before you attempt to update.My question would be that since you had updated to incremental point in the 5.x line for the ISY994 more than likely you didn't update again after because you might have a series 300 z-wave board and thus cannot update further. Since there is no support offered by UD and very limited support on the forums related to updates of unsupported hardware you would risk being on your own for any issues you stumble into if you do update. You might be at the point of it it isn't broke don't fix it. Are you having issues that you think an update would resolve issues?
