May 6May 6 Hi,I am getting "Error: Request failed with status code 404" when trying to view nodes or Error loading profiles when checking a program on eisy-ui. Tried locally and from the portal with the same results.ThanksGaryAll upgrades are done locally through the admin console.V 6.0.5Possibly caused by adding an additional eisy to my portal. Edited May 7May 7 by garybixler
May 7May 7 Hi Gary,Regarding the profiles error when checking programs, please try this url in a browser:https://eisy.local/rest/profiles/move/allWait a few minutes, then try again.If that does not help, please open a ticket.Regarding the 404, I assume this is when clicking on a node?I would suggest to take a look at the eisy-ui log. Download the log eisy-ui log under System | Logs. The log should tell you what is failing, that would give a clue.
May 7May 7 Author I just tried it again and the problem has been corrected after the second eisy went offline. The eisy I added has issues that is probably hardware related.Thanks for your reply.Gary
