Single Pico PJ2-3BRL controlling multiple shades
I have a Pico PJ2-3BRL which is programmed to operate multiple Lutron shades simultaneously. I am using a Lutron L-BDFPRO2 hub. After installing the Caseta nodeserver, the IoX AC shows two pico devices, a pico-main and a pico-fav (each shade is also present as a separate device). The pico-main has no available commands or status. The pico-fav has six available settings for "send command": On Off Brighten Dim FastOn FastOff. How in IoX can I perform the equivalent of, for example, pressing the Open button on the physical Pico remote?
The short answer is, you can't.
Lutron's protocols don't provide that capability. The plugin can't send commands as if they came from a specific device.
Pico's simply send button press commands to the hub and then the hub sends command to the device(s) linked to that. The plugin should also see that button press and you can use that in a program to trigger other events -- if control pico-main is on then do something. The top button of the 3BRL is the on button (regardless of what engraved on the remote).
You can also have a program that sends open/close commands to the shades, but you'd need something to trigger that. I believe you can also put the shades in a group and have some other device trigger commands (be the controller) for that group.
But you can't send commands to the Pico and Pico's have no status. They are very simple, when the button is pressed, the button press command is sent to the hub. The hub programming determines what happens when it gets that button press event. The node would have to know the topology of the hub to know what the Pico on/open button was linked to and then have a button/command to send the on/open command directly to those devices. I don't believe the hub will share that topology info and if it can, it hasn't been reverse engineered to know how it would work.
The -Favorite node is tied to the favorite button on the Pico and you can set how you want the plugin to treat that. The "Sends Command" setting is what the plugin will translate the Pico's favorite button into something that IoX can understand. Again, this would be used in programs. If set the button to "ON" then in a program you can use "if control pico-fav is on" do something.
