August 18Aug 18 Is there a way to move properties within the tile. I can move them up and down from the edit window but see no way to move them so that they are side by side in the tile, Initially when setting up the tile the properties did appear side by side but later as I edited the tile they no longer can be set that way,Thanks
August 19Aug 19 They will be side by side if the tile is wide enough.If they don't, then edit the tile, and look at the widgets. Do you have more than one "Properties" widget? If so, you may want to go back to a single Properties widget. Widgets are always one below the other, not side by side.
