10 hours ago10 hr This was an upgrade from ISY 994i 5.3.4. Communications event viewer shows failure to connect. I did open and re-save all the network resources as advised in the wiki somewhere. I wrote the network resources a long time ago and they were working with tcp. Is there something in the EISY that needs to be switched on to allow the network resources to work?
7 hours ago7 hr Author Copying each network resource to a new one seems to create a working network resource -- test button works and result is as expected. I only have 25 so if i have to copy them and then reset the names in programs that use them it's not horrible but obviously the wiki was not correct in my case that the network resources would transfer seamlessly and only need opening and saving to make them work.
7 hours ago7 hr Author Solution Success!! Exporting and Restoring the Network Resources made them all work. I hadn't noticed these options previously. Edited 7 hours ago7 hr by stillwater completion
