Longtime isy/eisy user, NOOB to eisy-ui - Need help
Ok, so apparently, I'm not understanding how to edit Programs and/or add new devices, etc. to my configuration using eisy-ui. With the recent announcement that the Admin Console & Java are going away I need to figure out eisy-ui. I've tried in both Microsoft Edge and Chrome browsers.
My first request to Universal Devices - PLEASE update the eisy-ui documentation to provide a step-by-step procedure on how to add devices (node members) and add/update programs.
I "think" I have edit enabled
Node Header icons
but I'm not sure what this allows me to edit. It doesn't appear to allow me to change anything (node name, move the device to a different folder, etc). If I click the '+' icon, all I'm allowed to do is create a new folder or group - not add a new node.
I can see my Programs, but I'm unable to change the name, add/remove programs, change if/then/else statements, etc. For example:
There are no 3 menu "dots", gear etc... to allow me to edit anything. Double clicking or right clicking anywhere does not seem to have any effect.
Any guidance would be greatly appreciated.
So... for example:
If you look at my scene above. Are you saying there's no way to change from "Time is Sunset - 29 minutes" to "Time is Sunset - 13 minutes" in the program If statement?
Right clicking, left clicking, dragging the box - all do nothing. I have to be missing something, somewhere...
59 minutes ago, ausgarretts said:
So... for example:
Please upgrade to the latest firmware.
Thanks Javi! Updating firmware fixed the issue.
I had assumed that since the display looked like the following that it was up to date. Obviously not. Once I clicked on Upgrade Packages it found the "new" packages and upgraded.
WAS
NOW
Thanks again Javi!
WAS
NOW
Thanks again Javi!
Great, also todays changes are in the beta, we will have may feature rich improvements in the coming days/weeks.
