Bye bye admin console polisy implications?
Reallocating the drive to use the full 64 MB is more work, because another partition has to be moved (partitions have to be contiguous). I also have a 64 GB SSD in one of my Polisys, but I left it configured as a 32 GB. The whole UDI software only requires about 6 GB.
Geeesh. I am totally about 250K x 1K blocked used but my df total shows about 5,500K x 1K blocks on the drive.
Somebody has been stealing my sectors!!!!
There must be a sector compaction command on freeBSD..maybe somewhat dangerous for a running system though.
I suspect the hardware in polisy may not handle more sectors than 32 GB of space.....eeeew, dread the thought.
Maybe I ordered too many pizzas on my polisy?
No, the hardware can handle both 32 and 64 GB SSDs. If you do have a spare SSD as you seem to saying try this: make a backup of your current system, then take out the SSD. Flash the new SSD the way you did it to recover and put that in your Polisy, then restore your backup. Now you're running a clone of your system, and do the filesystem expansion process as shown in the video. No risk for your original SSD.
I just realised that imagers require an image, not a file backup. Can the imagers produce an image from and existing HDD?
I gave up on Rufus last time. It didn't appear to be able to handle and image larger than 2 or 16 GB. I d/l another program (diskimager) and it worked just fine.
There still must be something wrong with 32 GB used up on this system. There has to be tonnes of spare space left, somewhere. Even the df counts don't add up to the totals. Three main folders show about 55MB each and a few others show 1-2MB each. I can't account for more than about 250 MB (0.25 GB). ?????
Did you get your eisy-ui into your 32GB partition?
Yes, I've done that: make a new image file. 32 GB is plenty of space for everything, including eisy-ui, plugins etc. The screenshot of my df command above is my test Polisy with all the latest versions.
Since you say you have 2 Polisys, why not make a new image file from the not reimaged one instead of the recovery image you got from UDI. It's that recovery image (I think it was 5.9.1) that had the problematic small image.
But post your df screenshot. I'd like to see it.
Edited by Guy Lavoie
I found info on expanding your freeBSD SSD drive partitions and so far...it seems totally successful.
It took some nerves and some guessing at system naming but I got through it.
https://kb.royalehosting.net/en/article/how-to-resize-a-freebsd-partition-eu4wlu/#2-3-resize-the-partition
The last line needs to use "zudi" instead of the "zpool" as listed. The line number 5 referred to was line 3 in my system.
I think I had to reboot my polisy when done as eisy-ui seemed a bit of a mess. Took a while to come back without insanity.
Things are much better. Lines are still little too fat vertically but much, much better. From what I can remember now, those boxes can never be filled out to the edges in HTML code. Nice going @Javi (pat on the back)
