How to setup eisy-ui
I've been using the eisy-ui pre-release for a couple of months and still have the Admin console.
I'm now lost in the weeds. I tried to migrate to the new eisy-ui. In trying to open I get a notice that eisy-ui can't be found.
Can anyone please walk me through all the steps to replace my Admin console with the new release of eisy-ui and if I need to and how to delete the pre-release if necessary?
Note: running on the latest Apple OS
Well eisy-ui isn't yet a replacement for admin console, but it's a great time to learn it, as it becomes more complete. If it was working before but isn't now, you should try doing "upgrade packages " from admin console. If that doesn't work, you might need to open a ticket.
Thanks. I'm up and running. I'm not sure if what I did this morning fixed it? In the transition sequence, I don't remember if I restarted or rebooted or if that madw a difference or not. Thinking about that, I manually turned off the Eisy computer itself and then turned it back on. When I tried to start the program, all was fine. I made a couole of adjustments to a program and created a new one to become familiar with the new interface and all seems fine.
