Thursday at 10:00 PM4 days Hello team! Can someone help me figure out why the next scheduled run time shows up as tomorrow and not today? I was able to fix it by changing the logic to 24-hours before sunset…..
Friday at 01:20 AM4 days I have had that happen to me after the 6.1.x upgrade.After fiddling with it for some time and trying several reboots, I finally got next runtime updating correctly, by making a same change to one of the times. I think I added a second to the time and then saved it. After it finished saving, I went back and put the item where I wanted and saved it again.I don't remember if I ran "run if" afterwards or not, but that got the next runtime squared away.
Friday at 01:36 AM4 days I think there is an item in release notes for either beta or staging update repo saying it includes a fix for calculation of sunrise or sunset times. Edited Friday at 01:36 AM4 days by hart2hart
Friday at 02:08 AM4 days My Eisy-ui sent me down the same rabbit hole. After making a mess of things, I decided to not pay any more attention to it. Presently all of my programs seem to be running on time. I also notice that the last run times and finish times are out of whack and some programs that I know ran are not posting any last run times. I believe that a future upgrade is going to correct this issue. I like Eisy-ui and am looking forward to using it exclusively.
Friday at 02:53 PM4 days All my sunset programs are also messed up. They all listing the next run time for sunset tomorrow night, instead of tonight. I made non-change updates to the programs (just hit the "update" button without an actual change so the program would then be savable), then saved them all and now they list the correct run time at sunset tonight. I suspect tomorrow I will need to do that again until such time as the firmware is fixed.Also, programs I have that run at midnight are running twice. Once at midnight and then a second time a few seconds later. I created a test program that does nothing but send me an email at midnight with a timestamp and it also ran double. So no chance of any hidden calls to it or anything, it is a brand new program with nothing else triggering it, just midnight on the clock. I tried changing the midnight program run time to a couple seconds after midnight to see if the issue is running precisely at midnight.
Friday at 11:26 PM3 days For what it's worth, I have also discovered that programs where sunset is used will run for one night after eisy reboot. They will not run the next night unless I reboot eisy. To mitigate this situation, I am currently rebooting once a day and then checking for updates!
Saturday at 12:21 AM3 days 53 minutes ago, Walt N said:For what it's worth, I have also discovered that programs where sunset is used will run for one night after eisy reboot.My sunset-based programs appear to be working now, presumably a result of updating to UI 1.3.6
Saturday at 12:51 AM3 days 28 minutes ago, oberkc said:My sunset-based programs appear to be working now, presumably a result of updating to UI 1.3.6Was that in beta? Been running in production only. Any major new issues with the beta build?
Saturday at 01:30 AM3 days 34 minutes ago, DennisC said:Was that in beta?Yes. Minor issues, but otherwise is a LOT of new capability compared to the production version. Beta still lacks a couple of key features that make it difficult for my purposes (cannot add nodes to groups or folders, cannot see node scene membership, missing network resources) but I can fill in some of the missing features with UDMobile.
Saturday at 01:38 AM3 days 7 minutes ago, oberkc said:Yes. Minor issues, but otherwise is a LOT of new capability compared to the production version. Beta still lacks a couple of key features that make it difficult for my purposes (cannot add nodes to groups or folders, cannot see node scene membership, missing network resources) but I can fill in some of the missing features with UDMobile.Thanks
Saturday at 03:01 AM3 days 3 hours ago, Walt N said:For what it's worth, I have also discovered that programs where sunset is used will run for one night after eisy reboot. They will not run the next night unless I reboot eisy. To mitigate this situation, I am currently rebooting once a day and then checking for updates!Yes, rebooting had the same affect as resaving programs. I updated to the latest firmware drop they did earlier today that Michel says fixes it. We'll know tomorrow after my sunset programs cycle past their shut down trigger.
Saturday at 03:36 AM3 days Presently UI 1.3.6 has not corrected this minor issue for me. I have a group of sunset related programs behaving oddly unless I reboot every day. Some of involve instion, others zwave. I am confident that this issue will be resolved with future updates. Good Times! Thank you all!
Saturday at 01:44 PM3 days The update UD posted yesterday did not fix the issue for me. After my programs ran at sunset last night and then sunrise this am, they are listed to run next as sunset . . .tomorrow (should be tonight).
Saturday at 02:03 PM3 days When you determine something truly not working as expected, open a ticket to report the bug. My sunset programs weren't executing. Through a ticket Michel and team have been very responsive, found bugs and published a version for me to test. It is improving fast. Someone above noted they weren't running the beta. With EISY-UI you need to get to the beta, it is becoming feature complete, and they need the testing and feedback to fix what's broken.
Saturday at 02:21 PM3 days 18 minutes ago, gdntx said:When you determine something truly not working as expected, open a ticket to report the bug. My sunset programs weren't executing. Through a ticket Michel and team have been very responsive, found bugs and published a version for me to test. It is improving fast.Someone above noted they weren't running the beta. With EISY-UI you need to get to the beta, it is becoming feature complete, and they need the testing and feedback to fix what's broken.Yes, I have a ticket running for a few days now about this.
27 minutes ago27 min After one day cycle on the latest software released yesterday, it looks like the sunset issue is fixed. My programs ran last night at sunset (which proves nothing by itself because fresh off a reboot, the sunset problem didn't exist), but now today the "next run time" is correctly listed for tonight. This is where it looks like the fix worked. Prior to the update, after running the first sunset it would then list the next run time ~48 hours later.
16 minutes ago16 min 9 minutes ago, apostolakisl said:After one day cycle on the latest software released yesterdayIs that 6.1.2_6 ?
