Using Notification Node Server from external process
Moved this post to Plugins > Polyglot v3(PG3x) > Notification area of the forum.
Has anyone successfully used the PG3x Notification node server REST API from an external process?
I'm working on a Raspberry Pi-based monitoring and control project for my water-well system. I'd like the Pi to be able to send alerts to my phone through UD Mobile, using the eisy Notification node server as the notification mechanism.
I already receive multiple UD Mobile notifications each day that are triggered by code running on eisy itself. That part works reliably. What I'd like to establish is whether an external process running on the Pi can invoke the Notification node server to send notifications through the same mechanism.
The Notification node server's Read Me describes a REST interface. I tried the following request from the Pi, using the eisy's configured address and REST port:
curl -X POST \
  -H "Content-Type: application/json" \
  -d '{"node":"udmobile","message":"The Message","subject":"The Subject"}' \
  http://192.168.7.241:8199/send
The server responded:
do_POST:Received: /send {}.
Code: 200
Command /send success
However, no notification appeared in UD Mobile.
Has anyone successfully sent UD Mobile notifications from a Raspberry Pi or another external process using the eisy Notification node server?
If so, I'd appreciate a working example of the request, including the correct endpoint, HTTP method, payload format, and any required configuration or node-server-specific details.
My objective is to have the Pi send alerts about significant abnormal water-well system conditions to UD Mobile, while keeping the Pi responsible for its monitoring and control-support functions.
I'm particularly interested in a solution that works over the local network, without having to implement a separate push-notification mechanism.
Edited by Michaelco
Moved this post to Plugins > Polyglot v3(PG3x) > Notification area of the for - Looks like a more appropriate location
