Variable Used Information Suggestion
I don't have a lot of variables, but I know as I have evolved my programs and thinking, some variables are no longer used and can be deleted to clean things up.
I would like to see an easy way to determine if a variable is used anywhere. For example, as a start, perhaps a new column "Variable Usage" which shows a count of how many instances of the var exists. Then perhaps be able to click on that and see a list of clickable links to the programs. But just knowing if a var is even used would be valuable.
Thank you,
Rob
Well, until Find/Replace is implemented in eisy-ui, you can use that feature in admin console to search for instances of variable usage. Just search for the ones you suspect aren't being used.
Hi Guy, yes, certainly I could do that. I was just asking for an improvement in eisy-ui to make it easier in the future! 🙂
Thank you,
Rob
