October 23Oct 23 hiIt seems there is only support for local (in the sense of development direcly on the eISY) - I normally use local towards the end of a development to test and ensure the installation works correctly. Is that nolonger possible ?
October 24Oct 24 In the eisy-ui do you have the Development button?In there is the Local Plugins but I don't recall if that was there before I created the plugins with eisy-ai.
October 24Oct 24 Author Local is different now. They run locally but do not test the install procedure from github
October 24Oct 24 I found the same in pg3x in the last 6 or so months. I would have to load into beta store and install from there to test the install procedure.
