October 25Oct 25 I think I have seen another post on this, but couldn't find it this morning. Working on a Scene where I needed to set Hue X and Y values.Screen opens up a drop down with value.. starting at 0.0001. I need values around 0.8400..To scroll down that far is not practical. Tried to input the number directly (which the open box says you can do), but there is no way to save it. Hitting return just resets the drop down. I am pretty sure this is a "global UI" issue, but havent verified it in other drop downs. thanks.
October 25Oct 25 I cannot replicate, in all cases when I hit "Enter" (tab fails) the number fills when it is a range entry. What browser?Range Entries (Enter value and press Enter...)Subset Entries (fFlter Values...)
October 26Oct 26 Author Mac Safari..This is a HUE bulb. I can enter / return for Brightness and Transition time, but NOT for x and y values.
October 26Oct 26 Is it due to precision 0.154 vs 0.1540? Even with this cannot replicate, it rounds to the closest number.You may need to open a ticket for this, include UUID and Node Name/Address.
October 26Oct 26 Author No its not a precision issue.I enter the full 5 digits plus decimal, which By the way, goes in very slowly and sporadically. Then it return and it immediately becomes 0.0000.Happens in both the Node and the Group / scene.. Ill open a ticket. I think you guys have access so you can try it.thanks. Edited October 26Oct 26 by dbwarner5
