Polisy Pro Migration WITH 700 ZWave to Eisy Lite
@bob123 wrote:
"Hopefully will get some time this weekend to attempt the migration from polisy to eisy and just moving the zooz dongle is all I need to do."
Bob,
How did it go?
I am in the same situation, and with an older Polisy that will not go beyond 5.4.4 without a system OS reflash, and a 700 series USB ZWave stick, it is the latter that is the big hold-up, as you know there is no backup option. Reportedly ( @Guy Lavoie ) unplugging, and plugging it into a (new) replacement Eisy may work. I also have some polyglot 3.0 stuff that will have to get moved.
I had another Polisy (cottage) that was a simpler setup, and no Z-Wave, which I did reflash, and it bricked at first. Was eventually able to get it going again with multiple reboots and some SSH twiddling - so a little gun-shy. It sits at 5.8.0.
I am concerned that after December I will lose access to my systems through the java applets. A bit frustrating as everything is working perfectly, and happy with the app. Unhappy with potentially having to spend a bunch of money (for an Eisy) and a bunch of time, and will essentially end up with the same functionality.
Orest
Edited by oskrypuch
I didn’t get a chance to attempt the migration yet. My feeling is that since the zwave stick records the zwave associations internally, it should maintain connections when it’s moved. I’m hoping the zwave nodes are in the general backup and simply resume working.
i think you should be okay after December with the Java front end- it’s not being turned off.
That's right, if you don't upgrade that Polisy and leave it as it is, admin console will keep working as it always has.
