Motion Sensor ver 2
My "old" MS of 1.5 years died and so I ordered a replacement (apparently only 1 yr warranty) and I noticed on the web the instructions have changed for ver 2 in that the "time out" is controlled via pots. Does that mean I cannot program the timeout via the ISY. In the past I linked the ISY to the MS then could set the exact time out (within 30 sec increments I think) very convenient, but now I have to rely on inaccurate pots? It seems that with pots, it would be a trial and error to get the right time.
I know many of you only use only the "on" command and the let ISY take care of the time out, but I have the light controlled by MS as well as in a scene controlled via a keypad, and right now I use the condition "If receive off AND keypad is off, then turn off light" so I need the "off" function
Joe
Jumper 5 installed allows you to do remote programming with software.
The updated users manual has details in it.
Thanks much! Sorry for not reading far enough!
Joe
Very cool! Thanks for the link! almost glad my last one died, looks like a significant improvement :) Do I need 2.8.3 to be able to do this?
Yes, 2.8.3 or above. I recommend using 2.8.4. There was a change in 2.8.3 unrelated to the MS that has caused some problems which was corrected in 2.8.4.
