replacing switches not passing through to programs
I have been replacing a lot of my switches recently. Programs weren't working right so I started looking into it and discovered that several of the programs including switches I changed out didn't get the message. They said something to the order of "not specified" or something like that where it should have had the switch. Some did transfer, but others didn't.
Hello apostolakis,
Do you know if those that were transfered had gone through "Replace Device" or whether or not you had removed them from ISY and then added the new one back in?
This was an issue with older UI but was addressed in 2.7.15. Knowing the scenario will help us figure out if this is a regression.
