Weatherbug Climate Temp into Custom Notifications ?
Is there a way to pass the any of the Climate info from weatherbug into a custom alert template ?
Would be interested in passing current temp if possible into notification.
thanks
J
That would be most excellent upgrade feature.
junkycosmos,
Was there a particular function you were trying to accomplish, or just a general question?
Art
  • 1 month later...
Hi All,
Thank you much for adding these into 2.8.11 ! Just tonight I got to upgrading from 2.8.10 to 2.8.16 and was really excited to see the inclusion of weather info in the alerts. Thank you !
To answer your way overdue question on ideas for use:
1. send alerts to myself and other family members when the temp is lower than X (say 5 F) before they leave for school. "Hey kids wear a jacket its X".
2. similar but as alerts to myself for covering the garden or be alerted when the temp outside worth of closing up the windows
3. Hum and pressure changes (rate per hour) used to trigger alerts for my wife. She has been suffering from sinus headaches which we suspect are due to pressure and or humidity changes. This could help us prove theory and maybe even help take action prior to her being a wreck.
Interesting point about #1 & #3 here is that now starts to bring the ISY into place where the rest of the family might feel value. Whereas today it is entirely out of their minds while doing all of its light and security management on their behalf.
Did have three items to inquire about.
small item:
in programming interface: Condition: Module: Climate: spelling is "Hummidity Rate" (extra M) but on ISY Climate tab it reads correctly "Humidity Rate:" Noted though that condition does appear to work fine :)
small question:
in programming interface: Condition: Module: Climate: pressure options are listed mBar but on ISY Climate tab it reads pressure in inches. (I am using station RSMSP) The conversion is no big deal however was not sure if this was intentional, known, or would impact program condition itself. Having the programming in mBar does give a very nice breakdown in selection.
larger question:
When I created the program below for task #3 above I ran into it repeating every 60 seconds. What I am trying to accomplish is to have the ISY alert me once every hour if that the climate conditions are true. Instead it is repeating every 60 seconds. I suspect that since my ISY is set to "read weatherbug data every 60 seconds" this polling is causing ISY to re-evaluate status of my program conditions and restart the program.
Is there an easy programming solution to this other than setting my polling to 3,600 sec ? Would like to avoid changing this by polling since we will want other programs to repeat at different intervals.
noted that the actual rates in here are just to test with:
Module 'Climate' Hummidity Rate >= -5 %
Or Module 'Climate' Hummidity Rate >= 5 %
Or Module 'Climate' Pressure Rate >= -17 mbar
Or Module 'Climate' Pressure Rate >= 17 mbar
Repeat Every 1 hour
Send Notification to 'J' content 'WeatherAlertShort'
Send Notification to 'M' content 'WeatherAlertShort'
Thanks much for any help here and to ISY Team for including the Weather info in the custom alerts!
J
Hello junkycosmos,
Thanks so very much for the detailed response.
1. Hummidity is a bug ... thanks so much for finding it!
2. The problem is that if you use Metric, then pressure is measured in Pascal. For English, we do NOT really know what WeatherBug is sending us (either mbar or pound per inches) ... I think you will be OK with using mbar
For your last question, I think you should use our new program variables (3.0.0 Beta to be released on Monday). This way, you can have a variable that is set when the email is sent out and unset when conditions change.
junkycosmos,
You want to read the weather conditions every 60 seconds and then Wait some time so one reading is not an anomaly.
With this set of programs the temp has to remain below 20F before a mail is sent. Then a notice is sent every 60 minutes as long as the temp remains below 20F.
Weather Cold
       Module 'Climate' Temperature < 20 °F
   And Program 'Temperature Cold' is False
       Run Program 'Temperature Cold' (Then Path)
       Wait  1 hour
       Run Program 'Temperature Cold' (Else Path)
When the temperature falls
Only runs if it was warm during last check
Weather Warm
       Module 'Climate' Temperature >= 20 °F
   And Program 'Temperature Warm' is False
       Run Program 'Temperature Warm' (Then Path)
       Wait  1 hour
       Run Program 'Temperature Warm' (Else Path)
When it warms
Only runs if it was cold during last check
Temperature Cold
       Wait  20 minutes
       Send Notification to 'Text to Blackberry'
Cold = True
Warm = False
Temperature Warm
       Wait  20 minutes
Warm = True
Cold = False
Rand
