March 13, 201115 yr Author Hi Jeff, Do you have Day Light Saving checkbox checked (Configuration | System) tab? With kind regards, Michel
March 13, 201115 yr Author Hi Jeff, I do not think they are related. Are you still having communications issues? With kind regards, Michel
March 13, 201115 yr Not home now but this morning I had to click ok ok a dozen times I had a couple after that For the record even with the release 2.8.16 version I dis get one a day or so I have about 10 access points as well as dual band devices. Also probably 25 filters so everything from washing machine to stereo to fridge is filtered Jeff
March 14, 201115 yr Author Hi Jeff, This does not sound normal ... actually, I have never seen anything like this. How dependent are you on your ISY? If you can live without full automation for a couple of week, I strongly recommend adding sections at a time and making sure you do not have any comm errors for those sections before moving on to others. Also, please note that increased number of access points may actually degrade network reliability ... as such, I would try figure out the minimum number needed for your installation and get rid of all the extra. With kind regards, Michel
March 14, 201115 yr Michel - Why would to many access points degrade the network? Would the dual band switches create the same problem?
March 15, 201115 yr Michel, I have just tried the upgrade again from a new clean install of windows xp. Nothing else loaded on this laptop. Errors start at anywhere from 3% to 17%. I don't know when I could have time to get on phone for help with this. Just seems to be strange that something so simple is not working the way it should. As I said before I have done several upgrades before this with no problems following my same sequence. Your support here is always great. Thanks
March 15, 201115 yr Author Hi dennisric, I am truly so sorry ... Please send an email to support@universal-devices.com with a few time slots and we'll do our best to accommodate. With kind regards, Michel
March 19, 201115 yr First of all, seriously, you guys are awesome for the continual updates on such a great product already. I LOVE the ability to customize notification messsages in the earlier betas and the last official release, and now, VARIABLES!!! Seriously, great job, especially with increasing features with complete backward compatability. Anyway, with that said, I THINK I have found an issue (it may already be known, and in addition, this IS a beta). This is apparently (but not definite) new to the 3.x release, I don't think I had it in any of the earlier betas, but it appears that my ISY is taking 1-2 seconds longer to act on triggers/events. I added a program using variables the other night and noticed it took a few seconds to execute. I thought not a big deal, it probably takes longer to evaulate the variables. But, the next day I also have noticed that ALL of the motion-controlled lights do the same thing now. They use to be almost instantaneous (less than a second), but now seem to be taking 1-2 seconds to do any action after an event. Anyway, like I said, this may already be known, it is a beta, and I cant say 100% sure its completely new in 3.x. Although, I can give a 80% confidence that it is. Anyway, not complaining at all, but just stating my observations. If this has been added, it would be great to get the perf back (especially motion controlled lights)
March 19, 201115 yr I am away and forgot my laptop power adapter for my MacBookPro. I borrowed a PC and did a quick change on the ISY. I noticed the progress bar stayed up. On the mac it randomly disappears and you have to go to event viewer. I borrowed a mac and tried the same task and it disappeared right away (1/2 way through the progress bar). As a newbee to all of this I thought stuff was done and started new tasks. Now I know to look at the event viewer to make sure it is finished. (and after UD had to assist in a rebuild of my ISY). Any way we can get this fixed with mac? Jeff
March 19, 201115 yr ... I added a program using variables the other night and noticed it took a few seconds to execute. ... Hi tim2u, Thanks for testing out the new variables feature. Could you please post your programs that are using variables as there should be no performance degradation at all.
March 22, 201115 yr I am having trouble keeping my ventstar linked up. It keeps telling me it can not communicate with it. I did a diag/device links table on it and it said: Failed reading device link. I can pull the isy module from the ventstar and replace and it works perfectly for a couple days then goes back to not working again. I am on v3.1.0
March 22, 201115 yr When creating a new program would you make it where enabled was defaulted to true?
March 22, 201115 yr Author Hi polexian, Please see this post: http://forum.universal-devices.com/viewtopic.php?t=5789 Programs are created Enabled. With kind regards, Michel
March 22, 201115 yr FWIW, I haven't found a repeatable set of events that causes it, but I'm still finding some new programs come up as disabled when first created with beta 3.1.0.
March 22, 201115 yr Author Hi fitzpatri8, Thanks so very much ... I had it happen once but could no longer reproduce it. So it would be great if anyone with this issue could give us the steps to reproduce. With kind regards, Michel
March 23, 201115 yr Hi Michel, I have actually seen this happen to me. It is not consistent. I just thought this was a default situation, and haven't paid much attention to the situation. I actually only noticed it after the posting of this thread. Clarence
March 24, 201115 yr Michael, This is what I did to get a program that defaulted to disabled.. Disabled two programs under the same folder Created a new folder Created a new program Wrote this: If kitchenlight is switched on then wait 1 hour and switch off. clicked save and it was disabled.
March 24, 201115 yr I have seen this problem before and know how to reproduce it. I have seen it happen many times. I am not yet using 3.1, tho it does happen on 2.8.16 and all previous versions I have used 1) Create new program. 2) Change the name of the program. 3) Write the program however you would like. 4) Save the program for the first time. 2 things will happen, 1 it will appear that you need to save the program again and, 2 it will not be enabled. Hope this helps. -j
March 24, 201115 yr Michel, I was able to finally get the upgrade from 2.8.16 to 3.1 to take. What I did was clear all my history and cookies from my browser and the update took but just a few seconds. The ISY is a great product with great support behind it. I am an old time X10 user from back in the 70's. Switched over to Insteon about five years ago. Your ISY product is light years ahead of any controller X10 could ever come up with. Thanks for your quick replies to questions. Dennis
March 25, 201115 yr Author Julian and Polexian, Thanks a lot ... this is tremendous help! Dennis, I am so very glad you finally got the upgrade to take. I was getting really worried!!! With kind regards, Michel
