Logging Thermostat Temperature
I wanted to log the temperature readings from my Insteon thermostats so I made this program (Windows .NET). It logs the temperature every 1 minute for all thermostats to a csv file for easy graphing. Can't say for sure if it will work with all the Venstar models.
http://www.sendspace.com/file/v4w4c0
Hello az1324,
Thanks so very much ... can you tell me what you mean by "Can't say for sure if it will work with all the Venstar models"?
Also, how do you use this information. Do you have a charting program as well?
I mostly graph them in a spreadsheet program. I didn't look into what the differences in the type value are for the different models so it only matches on 5.3.145.0 right now.
Hi az1324,
Can this work only locally? I tried to use this on my office computer, and entered in the IP address box the dynamic DNS URL I use to connect remotely & it doesn't work.
The link in the original post from az1324 is invalid 40 days later.
Does anyone have the original text for the program mentioned?
MSD
I would love to use this application as well. If the OP could repost a valid link to the application it would be greatly appreciated.
Teken . . .
I don't have thermostats to test but you could try this program, which logs ISY data to CSV as well.
viewtopic.php?f=79&t=7763
io_guy,
Thank you so much for sharing. :mrgreen:
Teken . . .
