Insteon program with no If conditions
If I create an Insteon program with no if conditions, does the ISY periodically run the program's then clause? On what schedule?
I might also add that if the program has run at startup enabled it will also run whenever the ISY is rebooted, whether manually or due to a power failure.
Sent from my SPH-D710 using Tapatalk 2
I always assumed that RunAtSartup meant RunIf-at-Startup. Will it actually run the then clause if there is no If evaluating to true ?
-Xathros
Tanks Lee and Michel. Good to know. I don't think my assumption has had any effect on my configuration but I like to know exactly what to expect.
-Xathros
