mmb
Everything posted by mmb
  1. I believe java support is ending specifically for Intel-based Macs (macOS x64) starting with JDK 27, which prompted the development of the eisy web based app. The writing is on the wall for java for consumers but it will live on in the enterprise cloud.
  2. The AI industry has driven hw prices so high that most people are giving new equipment opportunities a pass. I'll sit on what I have until prices are more reasonable, a few years I bet. Thanks for the info.
  3. Looks interesting, how do you manage the hefty resource requirements? Subscribed VPS?
  4. I use Google AGY to point to Home Assistant’s MCP along with an eisy/HA bridge to expose Eisy switches and some other useful devices. Programs are mostly on the Eisy, fast and easy. HA is what I use for dashboards that include the eisy switches, cameras (snapshots) sensors, weather, etc. I find the architecture straight forward and clean I like the UD Mobile on the iPhone, the wife loves it.
  5. I'm at the same release. Have you tried to log into eisyui? Likely the updates are related to that app.
  6. I have an api and a monthly. I considered it and it doesn’t work. DBG says missing modules but that was a few days ago. Running Claude fine now. Do you have Gemini working?
  7. I use the UD Mobile and and Notifications plugin. Actually nice not to have email clutter.
  8. Firefox has a handy url resolver so you can check what eisy.local resolves to. Type about:networking#dnslookuptool in the browser address bar. Mine looks like this: You can click DNS on the same page and clear cache there. Good luck.
  9. I didn't, eisyui/Settings. uncheck Enable PG3
  10. Yup, off Still thinking about the other problem, try https://eisy.local:443 to see if FF is doing something to the url.
  11. 3000 is the PG3 port. Is the PG3 service running? Does https://eisy.local/ work in privacy mode?
  12. I have Gemini but I gather the initial config of eiay-ai was for Claude. I did try a trial Gemini config using exactly the same json (adjusted) but the plugin was throwing errors. I purchased a Claude api key for $20 with no refill for testing for now.
  13. Firefox is a good browser but can be such a pita. Have you tried this? Delete site data?
  14. Ya, my brother went through these same problems, several Staging updates eventually fixed the AI problems. We worked through a ticket with UDI. One update replaces the Python libraries which takes a very long time, read up on that in the forums. After the update things started working properly and no errors.
  15. I don't remember is the AI node was present before adding the key. Have you restarted the plugin? Or rebooted the eisy?
  16. There actually is a Node, doesn't do anything except report Connected.
  17. Did you try Ctrl + Shift + R? My brother had this happen on his Mac using Safari, he had to go into Developer and delete his cache there, then it started working. Same experience with Chrome, worked fine.
  18. Gemini doesn’t work, unless something changed in the last couple of days. Spent a couple of hours as well. Anthropic’s Claude works fine, signed up for a no refill api key for $20. Eisy was updated with the latest. The JSON copy paste is tricky, paste into notepad add the Claude data then copy paste into eisy-ai plugin
  19. The latest updates, including the one today (1.4.11) finally fixed eisy-ai, I'm now chatting to my eisy. It says everything is healthy.
  20. Thanks Javi, he submitted a ticket. Michel was looking into last I heard.
  21. Ya the first thing he did was reboot and reinstall. The missing IOXPlugin is a bit baffling. Maybe it got lost as it's not one you can install yourself.
  22. Thanks, quite familiar with Configuration - Canadian permanent DL time zones what a headache. I was thinking more of a persistent header like the AC so when you're preparing a Program that is time dependent you're not having to jump out and see sunrise and sunset times. For example sunrise+1.5hr. Maybe I'm the only one that refers to it. Just a thought.
  23. @Javi have you seen this before? My brother is stuck at Starting after installing eisy-ai plugin: 2026-11-11 14:39:21.716 MainThread udi_interface INFO init:<module>: UDI Python Interface for Polyglot version 3 3.4.9 Starting... 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: File "/var/eisyui/ns/plugin_3/eisyai.py", line 8, in <module> 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: from ioxplugin import Plugin 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: : 2026-11-11 14:39:21.717 MainThread udi_interface ERROR udi_interface:write: No module named 'ioxplugin' He did install the most recent Staging modules rebooted as required.. Thanks!
  24. Is the time header going to be one of the ports Javi? I find it pretty handy.
