Everything posted by drprm1
Can’t set correct door state in program
Either one. They are programmatically equivalent.
Updated and now have xx(legacy) as drop down option of status in devices Ie. In programming Door sensors status has options for “Door status” and “Door status (legacy). Motion sensors have options for “motion status” and “motion status (legacy)….Same with vibration sensors Are they the same programmatically?
New Web/Browser Based Login 6.0/7.2
Shouldn’t that be https?
Favorites gone
Like Javi said, just tap the favorites tab
Favorites gone
Smart guy Hated the thought of redoing the favorites. Thanks!
Favorites gone
In UD mobile my “favorites” tab has lost all my favorites and now is exactly the same info as Home tab. Everything is there, controllable and with correct status. EISY 6.0.0_4 UD Mobile 1.4.3
TimeData node server for Polyglot2
https://polyglot.universal-devices.com
No prob. Like I said “is not closed” is fine. Thanks for looking into it!
Using version 1.6.3 Drop down options are open, closed, and unknown YoLink_11-1-2025_43441_PM.zip
Replacing a door sensor from Insteon with one from Yolink. Noticed in program I can set “Door State” to “Closed” but can’t set it to “Open”. “Open” is a choice in the drop down it just stays “closed”, doesn’t apply it. I set the line to “Door state is not closed” which works well just wondering about this.
Creating a button to run Then statement in a program
After everything we did yesterday I was able to do what I couldn’t before… (I’m using the version 1.3.4 not from TestFlight) Thanks again
Help button only confirms what I’m doing. There are no options in the Command box after trying to add command
It’s just a drop down with True or False. Tried with both but still no choices in “Command” box.
This is on Apple… When I click add command there are no options in the box to select Run If, Run Then…..
Network Error
As I said, it does work with different browsers I was looking for a Safari solution.
Network Error
Sorry if this has been addressed. I found one question about it with no answer. After upgrade to 6.0.0 when I try to login to UI I get this “network error” This is on iOS 26 which may have something to do with it. I can login successfully using other browsers…. Any way around this? Thanks!
EISY and Amazon Echo integration EOL?
- Hue Bulbs Unreachable
Deleted plugin and reinstalled. Back in business.- Hue Bulbs Unreachable
Router didn’t change anything as far as I can tell. EISY is on a static ip. It’s got to be just not finding the bridge? I removed the static ip for bridge from router, restarted router and it gave hue bridge a new address. I added it as a custom config in the plugin as key = bridges and value [“192.168.242”]…. Still no hook up- Hue Bulbs Unreachable
My hue bulbs show reachable as “false” in AC. No control at all. Hue bridge shows connected in AC. They show up and function correctly via Hue app. Plugin dashboard and details show connected. Router changed the bridge ip address lately and I changed it to static in my router and put a custom config parameter in plugin configuration to point to new address. AC and firmware both 5.9.1 Tried restarting Hue bridge, router and Plugin a few times. Restarted EISY and now in AC shows that hue bridge is connected but none of the bulbs are populated with any settings- The portal integration is down.
Rebooted and back on. Does “my.isy.io” just show if it is connected to my Eisy? UD mobile notified me that was offline so I assumed that meant the portal was down (like it has been recently). Where exactly would I see that the portal is down as opposed to lost connection? (If there is a way)- The portal integration is down.
Down again?- How to send email with current temp
Didn’t realize this question was in Yolink group. Never thought to use the node variable from the node server… Thanks! - Hue Bulbs Unreachable
