New Release 1.8.45
Hi
A new release of the Yolink node server (ver 1.8.45). There is a lot of changes below the surface to handle the Yolink API better. Node should be faster and take less resources.
Added quite a few devices (Most of the newly released devices and Thermostat2) and updated a few sensor nodes (The Yolink API was updated - THsensor and LeakSensor ) . Note, the new LeakControllers behave a little different than other devices - they go to sleep. Given this one should use the YoLink specified limits to trigger events. Also, they cannot sleep when added.
YoLink schedules are now in separate child nodes.
As this is a major update, so devices may not work - I have tested the ones I own, but there are derivatives of the devices and a few I do not own, so please help test and let me know if something is not work correctly
Note, there is a minor issue with the Dimmer - there is an API problem YoLink is working to fix - I hope once they release the fix the issue is gone, but I have not received the fix yet (probably low priority as it only related to controlling some attributes) - nothing critical
Edited by Panda88
missed info
The update installed fine will no errors that I saw. All devices are online in the admin panel. I did have to click update on the temperature sensor to get the current readings. The temperatures would have probably updated on their own if I waited.
A schedules child node was added in the admin panel to both water valves but nothing else.
Thanks for working on this.
