tlightne
Everything posted by tlightne
  1. @dbwarner5 I was able to do a backup with Eisy-UI connectiong through my.isy.io but it looks like there is no plugin options with Eisy-UI. The dashboard tab is still there if I login to use Eisy-UI 1.0.2 with a local web connection.
  2. I saw a post somewhere I believe it was from UD to access PG3x only through EISY-UI. Did you try that??
  3. I have a EISY at 6.0.5 and 9 Thirdreality Zigbee window/door open close sensors all working fine.
  4. @JLevy02 In Admin console click the Configuration tab then Email/Notifications tab then Customization tab. Set up Notifications there.. in the plugin store click on the Notification plugin then you will see a more info tab that has a lot of information on how the set up the notifications.
  5. @stillwater In UDMobile you can put your lights in a separate folder and set the icons to be a different color if they are on or off. This helps identify quickly which are on or off.
  6. tlightne replied to raydoc's topic in eisy
    Did you exclude it before trying to include it on the Eisy Zwave??
  7. Power down the Eisy then power cycle the router When the router is fully up and communicating power up the eisy..
  8. @KHenningsen The My programs the Geddy was reffering to is under the program tabs in the Admin Console top of the tree. Right click MY Programs then scroll down and select copy to clip board.
  9. UDM 1.52 on Android Eisy 6.0.3. None of my Zwaver devices show status in UDM also I can not operate any Zwave switches in UDM when I go to the device dashboard the only thing that showed up is device name everything else is missing. I restored to an older backup and everything was there until I did a sync.
  10. Looks like UD has released an upgreded version of the Dongle. The original was not LR.
  11. The Zmatter/Zwave dongel does not support Zwave LR.
  12. @DScanlan Always remove or exclude a new zwave device before trying to add it to your network.
  13. Why are you trying to keep it awake? If you are talking about the First alert Smoke detector it will continue to monitor for smoke while it is sleeping.
  14. @diggler I believe you set it up as a 4 button remote. When adding to insteon if you set it up as an 8 button you will get the A B C D E F G H definions in the Eisy then program it as Guy has posted.
  15. @haroldunger Think of it as one device that has three nodes. XX XX XX 1 Is the dry contact XX XX XX 2 iS The wet contact XX XX XX 4 is the Heartbeat XX XX XX is the Insteon address of the Leak sensor...
  16. @BHaus After the plugin is installed it will generate the nodes. The Admin Console is never used to configure plugins. In the plugin store after you select plugin there is almost always a more info button click on that and it will help you configure the plugin if it needs more information from you.
  17. Is it possible to create a button in UD Mobile to execute the then statement in a program. I am running the Harmony plugin and have several streaming services on my home screen of the TV. I can go to my programs in UD Mobile and run the then sttement but I would like to make is simple for my wife. Thank you all in advance for any assistance...
  18. @jkmcfadden I just did the upgrade this morning. I have Zwave locks, motion detectors, Fan controls, switches and a few others. I had no issues at all. All my Zwave functions as designed as well as my insteon. Like the looks of the new Eisy-ui cant wait for it to become full functioning. UD team did a great job with this upgrade.
  19. Harmony hub will work with Alexa+. I had to remove the Harmony skill and relink it to my Alexa account and it works without issues now.
  20. Since the 994 is no longer supported by UD I believe you can no longer upgrade to the PRO.
  21. tlightne replied to Techman's topic in eisy-ui
    Reading the complete article produces this information. – Using eisy? You’ll be notified of the upgrade availability for OS 14.3 and IoX 6.0.0 no later than 09/29/2025. Be sure to subscribe to our Product News and Announcements so you don’t miss it.
  22. tlightne replied to HTTRC's topic in ISY994
    You do not need to do a restores of a backup. Go back and reread the previous posts. Techman has given you the information to restore the PLM.
  23. I am working just fine...
  24. I am ok with not having position support at this time. I may upgrade to the Bond Pro at some time. I am good with having the stop command. My only concern is PG3 not reporting the correct version of the plugin. Thank you for all you do here...
