tlightne
  • Posts
    370
Everything posted by tlightne
  1. With Chrome the next step is the save button. Which displays to the right of the filename.
  2. @bpwwer I do not see it in the debug log. Thank you...
  3. @bpwwer Installed Ambient Console nodeserver and is not reporting Feels Like, Dew Point, and Lightning Strikes per hour. This data is displyed in the AmbientWeather nodeserver Main node. Can this be added to AmbientConsole? Love not having to get my data from the API. Thank you...
  4. Do you save the ISY Finder file?? If you do you can just reload it when the Java app resets the IP and port number..
  5. @walkman9999 I gave up on my remote because of the battery issue. I just use UD Mobile to operate Balli/Zwave shades independant of my Eisy.
  6. @Goose66 I am not worried about a refund you put up with a lot from people like me for the little you recover. I will try a second attempt in setting up a project in a couple of days after the hurricane has passed.. Thank you...
  7. @Goose66 It has been a week is there any information from @Michel Kohanim on the status of the project???
  8. @Goose66 Thank you for the update. I will wait for a response after you hear back from @Michel Kohanim...
  9. @Goose66 Still getting the same error Can't Link to UD Nest SDM Plugin.. I went ahead and purchased the plugin and installed it in a different slot on my eisy and still get the same results..
  10. @Goose66I installed the trial version 1.0.7 from the production store. When I authenticate it brings up the Google choose an account screen. I select the account to authenticate with and brings up a screen that states:Can’t link to UD Nest SDM Plugin Please contact Universal Devices if the issue persists Do I need to setup anyting additional with google? Thank you...
  11. Ambient is having problems. I see them everyday several times a day...
  12. Purchased and installed an additional temp sensor today and now all the sensors show and update properly in admin console Plugin nodes on EISY....
  13. @bpwwer Ok thanks for looking into this. I may order another sensor from Ambient and add it as an additional sensor to see what happens...
  14. @bpwwer Hi Bob, Main with address e8db84e738-1 is the outdoor array and is working as designed. indoor with address e8db84e738_2 is as labeled the indoor sensor and is working as designed. one with address e8db84e738_3 is a sensor in a chest freezer and is working as designed. Two with address e8db84e738_4 is monitoring temps in my bedroom and is working as designed. Three with address e8db84e738_5 is the temp sensor the is not being updated. Attached is the download Package. Thank you.. AmbientWeather_6-28-2024_63232_PM.zip
  15. @bpwwer My Eisy crashed while upfrading PG3 to 3.2.27 and had to send it in to UDI to be reflashed. After returning and reloading PG# backups my Ambient Plugin loads all the nodes to my Eisy and the data gets updated except one an indoor sensor that I measure AC supply temps get any data. I have rebooted Eisy a couple of times with no luck. I have deleted the plugin from Eisy and PG3 rebooted EISY then reinstalled the plugin but still do not get the one node to update in EISY. I see the all the nodes in the AC console it just will not update the data. I have looked in the logs for the plugin and I can see the data get updated from the API. I have attached the log file here as well. EISY Firmware is 5.8.3 and PG3 is 3.2.27. Thank you.. AmbientWeather_6-28-2024_31954_PM.zip
  16. Open a ticket with UD at this link... https://www.universal-devices.com/my-tickets/
  17. I would wait too. Sure wish I did. I hit the update packages button around 2:00 this afternoon and have been out of the water since. I have a ticket open but have not heard anything from support yet...
  18. Hit upgrade button in AC console and received two messages the upgrade was in progress. Waited 20 minutes no other messages received in AC console Finally received message upgrades complete. Never received message to reboot so waited 10 minutes and did reboot from AC console. Hit reboot button on AC console nothing happened. Waited 30 minutes hit multi function button on Easy to shoudown. After shutdown removed power waited few seconds and repower up and booted. Never received anything from Easy. Tried to SSH in and get connection refused. LOX finder says not found. Eisy does not show online in portal. I think I am hosed. I have opened support ticket..
  19. @Goose66 I have downloaded the plugin but after spending a couple for days of attempting to get the Google side set up I was unsuccessful. I would love to see you persue and easier setup.
  20. @bpwwer FYI.. Received this email today from Open Weather....
  21. Mine pared with Eisy with no problem. Follow the instruction from Bali and the remote will work after you include them in Eisy..
  22. @glacier991 Login to your account and scroll down you will see an API section with a "generate API button"
  23. https://www.universal-devices.com/my-tickets/ Go here and open a ticket with UD..
  24. There is only two nodes. Indoor and Main unless you have optional sensors.
  25. @Goose66 Thank you...
  • Create New...
